Seats - Del Sol vs. s2000
Old Oct 8, 2002 | 03:21 PM
99ls's Avatar
Default Seats - Del Sol vs. s2000
In my quest to find a lower sitting seat for my Integra, I have come accross a set of factory leather Del sol's and a set of s2000 seats.
The leather on the del sol's is in ok condition, but will probably need to be refinished. Considering the price for the refinishing, the price for the del sol's will be about $2-300 less than the s2000 seats.
My question is, which set will offer the lowest seating position in an Integra?
Which set will be better for the money? Also, which seat will offer better support?
The del sol's are basically a "bolt-on" job after replacing the rails with Integra rails, but the s2000 rails will have to be modded to fit.
What should I go with?
Old Oct 8, 2002 | 03:49 PM
JCushing's Avatar
Default Re: Seats - Del Sol vs. s2000 (99ls)
factory del sol leather?? what model did this come in?
also what do you have to do to get s2000 seats in ? just modify the rails?
Old Oct 8, 2002 | 09:32 PM
99ls's Avatar
Default Re: Seats - Del Sol vs. s2000 (JCushing)
The leather was an option, or so the seller says. And yes, to get the s2000 seats in, the rails need to be modded a bit.
Old Oct 8, 2002 | 10:00 PM
Weston's Avatar
With the Del Sol seats, how much lower do you end up sitting? I could use some more head room, especially when auto-x'ing with a helmet on. Is the seat height adjustable or anything? How comfortable are they? Do they hold you in place as well as the stock Integra seats do?
Old Oct 9, 2002 | 03:44 AM
SubieDude's Avatar
Go with the S2000 seats...they will give you the support you will want..and you will have a lower seating position...you might pay alittle more too...but hey how many people have you seen with S2000 seats in an integra
Old Oct 10, 2002 | 04:11 AM
stevecockrill's Avatar
Default Re: Seats - Del Sol vs. s2000 (WhiteS2)
Go with the S2000 seats...and you will have a lower seating position...
I don't know if the S2000 seats actually do permit a lower seating position than the del Sols.......
S2000s are nice, but they're quite pricey. The del Sol leather seats were actually offered through a 3rd party company through the dealership as far as I can tell.
Steve
Old Oct 10, 2002 | 04:17 AM
Rory Breaker's Avatar
Default Re: Seats - Del Sol vs. s2000 (stevecockrill)
S2000 seats supposedly drop you a good inch to an inch and a half. So, you'll be sitting pretty low.
If I was spending that much money, I'd go for a nice used set of Torinos/Recaros. But if you have to pay to have the seats redone...forget it, you may as well go with the S2K seats, IMO.
Old Oct 10, 2002 | 10:32 PM
99ls's Avatar
Default Re: Seats - Del Sol vs. s2000 (newgsrdriver)
What's the best way to get answers? Find out yourself; so I did. Just picked up the s2000 seats and dropped them into my car. More info on the install can be found at: https://honda-tech.com/zerothread?id=303090
So did they sit lower than stock? Yup, about 2 inches; now I can sit straight again! On top of that, the support is excellent, wrapping you in them like your girl hugging onto you and not letting you go... Simply awesome.
The only bad thing I can think of is now I feel like a kid trying to drive my dad's truck; the steering wheel is higher than I would like, but i'll get used to it.
Above all, the seats are wonderful and my back is already thanking me.
Quick snapshot:
[Modified by 99ls, 11:36 PM 10/10/2002]
Old Oct 10, 2002 | 11:00 PM
ALF's Avatar
ALF
That's awesome!
I want some now...hehe.
Old Oct 10, 2002 | 11:48 PM
Calavera's Avatar
Default Re: Seats - Del Sol vs. s2000 (ALF)
Is modifying the rails for s2k seats hard? What kind of hardware do you need?
Old Oct 11, 2002 | 12:05 AM
99ls's Avatar
Default Re: Seats - Del Sol vs. s2000 (Calavera)
Somewhat. The 2 holes on the front of the rails had to be bent down to an angle to match the holes on the car; I used pliers for that.
The rear bolt hole on the inner rail had to be filed down a bit to enlarge the hole so that it can align with the hole on the inner side.
The trouble starts with the rear bolt on the outer rail. The bolt hole is horizontally mounted, but the rail is vertical, so the rail needs to be bent down at an angle like the front. But that piece is too long, plus it's made out of harder material. What I am planning to do this weekend is trim that part down and then maybe heat up the area to soften it up so it can bend easier. Then I redrill a hole into the rail and presto.
[Modified by 99ls, 1:23 AM 10/11/2002]
Old Oct 11, 2002 | 12:42 AM
tegaholic's Avatar
I got the same setup in a 00 teg... I like it but sucks trying to get people or things into the rear seats. Cause seats dont move up much.
I got the 2 rear bars cut and shortened then rewelded. Then used oem bolts. The welder did a great job for only $80.
The rails look like oem now. How much did you pick up your seats for?
JJ
Old Nov 21, 2002 | 12:39 PM
LillDragun's Avatar
Default Re: Seats - Del Sol vs. s2000 (tegaholic)
can you get a pic of the rails? i am trying to get my hands on a pair of black s2k seats but one of my main concerns is the seat moving forward and back
nitrotiger
Mar 21, 2010 02:18 PM
jdmsolmate
Mar 24, 2005 09:05 AM
Edulerp
Jan 14, 2005 08:49 AM
Typical Lucas
10
Jul 26, 2003 09:58 PM
brokestock
Nov 29, 2002 11:54 PM
