type r lip install help
Old Oct 8, 2002 | 03:19 PM
lessthndan's Avatar
Default type r lip install help
im getting a itr lip....does anyone know where i can get the screws for installation or can i use any type for it? thanks guys!
Old Oct 8, 2002 | 03:57 PM
ITR#00-1077's Avatar
Default Re: type r lip install help (lessthndan)
You're getting a used lip I presume.. well, just get screws that will fit into the holes that are already pre-drilled on the lip.. a screw that is .5" long will do the fit and some double sided tape can be used if you want it that secure.... other than that.. they're not special screws.. just some regular ones... if you want the exact screw sizes... I can check the ones in the box I have... it's brand new and all hardware is still there...
Old Oct 8, 2002 | 05:00 PM
01gizzer's Avatar
First where did you get your lip and scondly you can pick them up at your local Acura store.
Old Oct 8, 2002 | 05:05 PM
Eric R's Avatar
IF you're getting the real ITR lip, not the copy of OEM, then you'll need the right OEM screws which are designed not to crack the lip. They should supply them at the dealer as a regular part number. BTW, original ITR lip does not require two sided tape for install.
Old Oct 8, 2002 | 08:19 PM
mstewar's Avatar
Default Re: type r lip install help (Tweety R)
yep.. dealer's got em.. you'll probably have to order them.. make sure to get the 4 screws and clips for the wheel wells, and the 6 screws and clips for the underside.. should be about $20 or so for all of them.. good luck..
Old Oct 8, 2002 | 08:27 PM
lessthndan's Avatar
Default Re: type r lip install help (mstewar)
thanks for all the replies guys..its from a 01 PY itr.....ill check the local dealership tomorrow..thanks again!!
wolf95
11
Nov 10, 2009 09:36 AM
1990JDMCRX
May 17, 2009 10:43 AM
Samuels
May 11, 2008 11:28 AM
rawNArsxS
May 8, 2008 02:17 PM
integranator
Dec 9, 2002 06:47 AM
