where does this wire go (ABS fuse box)
I just bought a 95ish Integra. The ABS light is on, and I traced part of the problem to the ABS fuse box under the hood. There is a heavy gauge wire going from it to the vicinity of the battery, but it has been disconnected. Below is a picture of the fuse box and the wire. Is this wire a ground, or does it get +12v?
Thanks in advance!
Justin
Thanks in advance!
Justin
^^^^^ i dont know much about abs but i would look to see if you have any blown fuses in that little fuse box...or any fuse box for that matter there are 3 in total.
Thanks! I suspected it went to +12v, considering the general location of the wire. But ya can never be too safe.
Mike, I did check the fuses, and they all look good.
i dont know much at all about abs...havent had a problem with it yet...i know there is fluid in it though so maybe its low??? also maybe it will throw a code when you scan it??? someone help him
Well, I hooked up the wire and drove it around for a couple minutes and there doesn't seem to be any problem. No light, brakes work as expected. I'll drive it around some more tomorrow when the roads dry.
Funny thing is, I bought this car dirt cheap because the owner was concerned when the ABS light came on. Apparently last time it happened he shelled out $1800 for the repair. And this time it seems like the only problem is that someone forgot to reconnect that wire when they replaced the battery!
coupedragracing
Sep 5, 2006 02:52 PM
ramz7887
Dec 4, 2005 01:44 AM
