Am I missing something on my transmission?
It's called a "Clutch Case Cover", #1... http://www.acuraautomotiveparts.org/...s=&view=normal $25 or less at the dealer, under $5 at your local PicknPull.
It is there to prevent debris from entering the clutch case, you do not want a rock off the road thrown up there, it can damage the flywheel and take a "chunk" out of your lower engine case. 94
Type r covers are made of aluminum and help join the engine to tranny. Even the stamped steel ones use brackets that help join the engine and tranny. I couldn't tell from your pic if they were installed but if not you should get them. They are the two brackets in the second pic
BoostGoneWild
Feb 23, 2007 05:13 AM
[/IMG]
