b16 pistons in a ls
Old Jan 11, 2012 | 02:02 PM
tyler_schaeffer's Avatar
Default b16 pistons in a ls
im planning on putting b16 pistons on ls rods with arp rod bolts and and arp headstuds. im just trying to get some advice on weather i should use pr3 or p30 pistons, and if ill have to do anything to the timing or to the motor while im in there i plan on putting some new rod bearing will this need tuned and how much power should it make. if you done this set up before please let me know how it went and what you did
Old Jan 11, 2012 | 02:16 PM
Str8EJ's Avatar
Default Re: b16 pistons in a ls
common combination, everything is capable of working together.
not sure about the specifics of your engine, but pretty sure a tune would be in order. setting timing is part of the tuning process.
p30 yields a slightly higher compression ratio compared to pr3, all else remaining the same.
Old Jan 11, 2012 | 02:25 PM
hybridmiklo's Avatar
I hate when people asked these questions and then asks how much power will it make. Do some searching. There is actually a big thread dedicated to the b18non vtec in this exact forum. Do lots of reading, it sounds like you don't know very much and could use somre reading.
Old Jan 11, 2012 | 02:27 PM
D.A9 GUY's Avatar
HES ASKING AN OPINION question not whats a b16!!! stop being a jerk
Old Jan 11, 2012 | 02:43 PM
im just trying to get some info on how the motor ran and if they ran into any problems
Old Jan 11, 2012 | 03:09 PM
wishingiam's Avatar
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/%22official%22-all-motor-ls-b18a-b18b-dohc-nonvtec-2108181/
Old Jun 17, 2012 | 12:58 AM
Douglas Norwood's Avatar
hey bro dont worry im doing the same exact build and soo far ive found oout that
the compression is going to be around 11.96:1 so almost 12s we are gonna break race gas but ive talked to a guy a bizzy and he said that if i just break it in and go tune on 91 itll be fine but i think you should get somewher around 210hp and a frriend said he made like 170 to the wheel
SIC_DA9
Feb 20, 2008 07:31 PM
Civichatch2k
Oct 18, 2005 12:10 AM
kerby116
Feb 29, 2004 07:43 PM
gocivicgo
Jul 16, 2003 12:09 PM
ls_vtec_b18a1
Oct 13, 2002 04:00 PM
