help!!!!! 88 crx
Old Jan 11, 2012 | 12:01 PM
robb88crx's Avatar
Default help!!!!! 88 crx
so i bought an 88 crx it has the 1.5 bought it non running sounded like the timing was off but i took off the valve cover and removed the top piece of the timing cover and belt was new and was not dammaged..it still wont start any ideas?
Old Jan 11, 2012 | 12:07 PM
jdmef69's Avatar
Default Re: help!!!!! 88 crx
Maybe a little more info would help. We can diagnosis a problem when you say it won't start... What's it doing? Not cranking, cranking? Do you have fuel, spark?
Old Jan 11, 2012 | 12:11 PM
robb88crx's Avatar
sorry lol its just cranking it has fuel i dont think its getting spark already bought new plugs and wires
Old Jan 11, 2012 | 02:05 PM
MONSTERZC's Avatar
This is what you can do to test for spark. Pull a plug insert in to a wire. Then hold the plug against a grounded bolt. have someone turn the key a couple of time to see if you have spark. Do this for each wire.
Old Jan 11, 2012 | 02:07 PM
BigbamaBen's Avatar
The distributor goes out quite often. Check that
Old Jan 11, 2012 | 02:50 PM
jdmef69's Avatar
Simple test. Easiest way to check spark
Old Jan 12, 2012 | 10:52 AM
robb88crx's Avatar
i just replaced all plugs new distributor and rotor.. how do u add pics on here because when i replaced the rotor i saw something that looked like it was melted.. around something that is magnetic? sorry im just geting into hondas from driving my 350 chevy lol
Old Jan 12, 2012 | 10:53 AM
robb88crx's Avatar
http://pictures.sprintpcs.com//mmps/...ideo=true&wm=1
sry its not the best of pictures...
Old Jan 12, 2012 | 12:21 PM
crx_si-r's Avatar
fixed
Old Jan 12, 2012 | 02:41 PM
crvtectim's Avatar
Lol, I can't make out **** in that picture.
Old Jan 12, 2012 | 06:12 PM
89CRXSi_24's Avatar
Could be a number of things: Anything with the fuel system, distributor could be loose, even the wires at the ignition coil or a faulty coil
Old Jan 13, 2012 | 07:17 AM
MONSTERZC's Avatar
Did you check to see if the timing was off or did you just check the belt condition. It sounds like you are on a wild goose chase. If i was you i would have it towed to a shop. It would be cheaper and faster than just throwing parts on the car.
Old Jan 14, 2012 | 05:07 AM
robb88crx's Avatar
the belt is fine...i think its the dizzy the cord runing down from there is melted....could be another possiblity
Old Jan 15, 2012 | 04:16 PM
MONSTERZC's Avatar
If there is something melted in the dizzy then replace it. Just because the belt condition looks fine, doesn't mean the cam timing still isn't a tooth or more off.
rexfiend1877
Jul 29, 2008 02:54 PM
dboz3403
Sep 20, 2007 10:25 PM
99sonicbluegsr
Sep 27, 2004 10:35 AM
Goshenjohn
Aug 1, 2004 04:50 PM
krazyDOHC
Apr 14, 2003 08:58 AM
