EG Coupe Master Cylinder question
Old Jan 11, 2012 | 08:13 AM
Wilka's Avatar
Default EG Coupe Master Cylinder question
I have a 94 ex coupe with a rear disc swap from an integra, what other master cylinders will fit or increase braking performance perhaps? I think I've seen them fit s2k ones on in an insue of super street honda edition but do any modifications need to be done in order to fit it or is it even a big difference?
Old Jan 11, 2012 | 08:21 AM
grumblemarc's Avatar
The Grumpiest
Default Re: EG Coupe Master Cylinder question
What's wrong with the performance as is? And how much of an "increase" do you think you'll gain?
Old Jan 11, 2012 | 08:24 AM
Wilka's Avatar
I don't know but mine is bad and leaking, it needs to be replaced, and I was just interested because I see all the Hondas in the magazines with swapped master cylinders
Old Jan 11, 2012 | 08:26 AM
The Grumpiest
I heard you can use one from a Prelude. Never remember seeing any data for increased stopping distances.
Old Jan 11, 2012 | 09:02 AM
Wilka's Avatar
What about just using the stock ex one? will that hold up with the rear disc conversion?
Old Jan 11, 2012 | 09:29 AM
angrysmileyface's Avatar
91 EX sedan (15/16) fits perfectly. No line bending.
Old Jan 11, 2012 | 09:32 AM
Wilka's Avatar
Would the regular ex one still work for my rear disc though?
Old Jan 11, 2012 | 09:35 AM
DId you change the proportioning valve?
Old Jan 12, 2012 | 12:52 AM
Wilka's Avatar
I have no clue, I bought the car like this.
Old Jan 13, 2012 | 03:12 AM
ddd4114's Avatar
You'll get a stiffer pedal with a larger master cylinder, but it's more likely to decrease braking performance. The only time you really want to go larger is if your pedal travel is excessive.
Old Jan 13, 2012 | 04:19 AM
Libertariat's Avatar
Ek Forever y0!
A rear disc swap does not justify a MC upgrade. Only if you need more fluid to operate larger brakes in the front is one really necessary.
You do need a new prop valve if you don't have a 4040
vtecturbo18
23
Nov 5, 2009 11:42 PM
stealthcivic94
May 8, 2007 06:53 AM
BoRiCuA
Feb 20, 2007 03:03 AM
DEIVIONCRX
Feb 10, 2006 10:21 PM
Civic_EX_turbo
Feb 15, 2004 05:52 PM
