d15b6 to d15b2
hey guys need some guidance on this swap. 88 crx hf (orig d15b6 8 valves mpfi) engine shot. replaced block and head with d15b2(16 valves ) used hf manifolds. problem: vaccum leak egr engine idles rough disconnect egr engine runs smooth and no power on highway. the block and head were completely rebuilt. any ideas....please help....thx
Switch to an Si (PM6) intake manifold and throttle body, preferably the exhaust manifold too, and use an Si ECU (Si camshaft preferably as well but not necessary). Or you can remove the head and rebuild your original 8 valve head and correct the problem.
The problem is that you are using 8valve HF specific equipment on a 16valve DX engine.
Can't see why it wouldn't work.
Are you saying your EGR is leaking vacuum? - if so, you probably have a Check Engine Light while driving as well.
Or is something else leaking vacuum?
im getting conflicting info on this swap. some are saying u can use a d15b2 block and head on a 88 crx hf (orig 8 valves) using hf manifolds and ecu with no issues. can someone help with this please.....THX:
aznfab
Jul 24, 2003 09:06 PM
