Prelude Auto Transmission
Old Jan 10, 2012 | 06:46 PM
LSVTECKID's Avatar
Default Prelude Auto Transmission
What transmissions will work with a 2001 Prelude? I've read a little information saying that only a 2001 transmission will work with the 2001 Preludes. Any other insight as to what other options I have (please no 5sp swap as this if my fiances car).
Old Jan 10, 2012 | 08:08 PM
asianpoet's Avatar
Default Re: Prelude Auto Transmission
any F or H transmision (prelude or accord) will fit..
Old Jan 10, 2012 | 08:10 PM
v8killaz's Avatar
im pretty sure only 97-01 prelude trans will work. and yeah those transmissions are junk. you might as well stock up since they go bad like every oil change
Old Jan 10, 2012 | 09:41 PM
LSVTECKID's Avatar
I've been getting mixed information. Local guy told me 01 transmissions were different from 98-00 transmission. Something about the transmission had different components mounted differently. Is there really any issue with that or was he just talking out of his ***? I'm not really familiar with auto transmission as all my vehicles are manuals.
Old Jan 10, 2012 | 09:45 PM
psud3ity's Avatar
The transmissions are basically the same with the same failure rate. Won't matter.
Either way, iirc, the lawsuit regarding transmission failure occurred before the 00-01 cars were out or were able to experience failures on the scale of the 98-99 transmissions. so they weren't included in the warranty extension. There is no fundamental design difference in the transmissions.
And as an owner of two seperate 2000 model year automatic transmission/paperweight, I can tell you they are no better. A brand spanking rebuilt one straight from the Honda dealership lasted 40,000 miles.
Old Jan 11, 2012 | 07:46 AM
LSVTECKID's Avatar
Surprisingly the transmission has lasted 138k miles and is just now giving out. But the original plan is to get it fixed so we can sell it and get her a sedan.
thanks
Old Jan 11, 2012 | 12:13 PM
Kane666's Avatar
any prelude auto trans from 97-01 will work. possibly a h23a vtec auto trans as well but i have no idea and since everyone is 5 speed happy im sure no one else has used that auto trans lol or tried.
Old Jan 11, 2012 | 02:36 PM
nemesis25's Avatar
Mechanically, you can use any M6HA transmission. Electronically, you will have to get a new second clutch, oil pressure switch from a 2001 model. Also, a shift valve A+B, from a 2001. I do believe, there is something else.
Old Jan 11, 2012 | 02:37 PM
nemesis25's Avatar
I do remember, you'll need the shift control valves B+C, from a 2001.
Old Jan 11, 2012 | 02:51 PM
nemesis25's Avatar
Just so you know, the M6HA transmission is very reliable, if maintained correctly. By this, I mean installing an oil cooler and changing the oil very regularly, usually 7000 to 8000 miles. The service manual doesn't say this, but take it from someone who has pulled too many of these apart, to find the exactly same issue in every one of them. The reason, I believe that Honda can't seem to have fixed it is cause, they're by the books with no common sense or trying to apply resources to something, they no longer make.
Old Jan 12, 2012 | 05:20 PM
DrewsPrelude's Avatar
My auto trans 2gear and 3rd were constantly slipping. So I just got it replaced but the mechanic had a hard time finding another transmission from the 97-01 prelude. I believe he took parts off an accord. Don't quite know what year but Ill find out.
salvageland
Oct 28, 2004 11:14 AM
UA6 BALLER STATUS
Jul 24, 2003 06:00 AM
Matgallis
Apr 16, 2003 04:18 PM
1994integraLS
May 11, 2002 04:49 PM
