Entire floor sopping wet 95 Civic hatch
Old Jan 10, 2012 | 06:26 PM
PaddyV's Avatar
Default Entire floor sopping wet 95 Civic hatch
So my friend has a 95 Civic hatch and the entire floorboard is/was sopping wet since it was purchased. I've read through several threads regarding wet floors and have tried several suggestions, though in the threads I saw only a part of the floor was wet.
I pulled the seats and carpet from the car, dried up the floor with towels and looked everything over. It was only the floor that was wet, the spare tire well behind the back seat was completely dry.
With the car outside I had my friend spray down the whole car along every seal... Windshield, doors, windows, and hatch. No leaks! I even got underneath the car and looked for rust spots... nada.
The car doesn't have a sunroof or AC, so it can't be the drain tubes for those. I've checked the coolant and it's full, there's no coolant smell in the car and the heater works just fine, so I'm eliminating the heater core as a source.
For now I told my friend to drive it without the carpet and see if water still comes in. Hopefully we'll be able to spot the source. I just finished putting everything else back together and parked the car, it sits outside. For now it's dry since I dried it up, but we'll see what happens.
Does anyone else have any suggestions or explanations as to why the entire floor would be soaked?
Old Jan 11, 2012 | 07:08 AM
jasoncrashtech's Avatar
Default Re: Entire floor sopping wet 95 Civic hatch
sit in the car (with the windows and doors closed all the way) with someone on the outside running water over the car. look and listen for the leak.
sunroof, side glass, doors, check the driver floor (sometimes it leaks through the antenna ) all while running water all over the car.
hope you find it
Old Jan 11, 2012 | 10:52 PM
BrownDx's Avatar
I had a car that got a soaking wet carpet like you described, and I concluded that it was the drain in the hood cowl area.
Old Jan 12, 2012 | 05:19 AM
Hawkze_2.3's Avatar
Try spraying the water at the car with a hose nozzle, sometimes it just takes a little pressure to find the leaks.
Old Jan 12, 2012 | 02:24 PM
PaddyV's Avatar
I'll look for that drain hose. Otherwise, I did sit inside as my friend sprayed the car down. No apparent leaks.
Will definitely be looking for that drain hose.
Old Jan 12, 2012 | 03:49 PM
sirEGhatch's Avatar
i had this happen in my old civic. there was a hole under the whiper motor. kinda ubove the fuse box
Old Jan 14, 2012 | 09:48 PM
B and B's Avatar
Loved
Community Favorite
Check under drivers wheelwell where hood cable goes thru. If the grommet/boot thing isnt sealing the hole, water flys in.
Does it have fender liners?
Old Jan 16, 2012 | 05:48 AM
PaddyV's Avatar
I'll be checking out all of these possibilities...
I did have a nozzle on the hose, we were using a jet stream on it, so there was a bit of pressure wherever the water was hitting.
I'll check out the previously mentioned areas and post feedback once it's thoroughly investigated.
Old Jan 16, 2012 | 11:26 AM
don't use high water pressure. without a nozzle is what you want to use, like a heavy rain or a car wash is what your trying to imitate. sometimes leaks are hard to find, water can find little spots and cranny's and over time can through urethane (glass leaks) or rust holes.
do you have a sunroof ???
Old Jan 20, 2012 | 01:59 PM
CBL9's Avatar
Any luck finding the leak? I have a 95 sedan that only the passenger side leaks. I also have poor heat. Not to hijack your thread but can anyone elaborate on the heatercore leaking and causing this problem?
I have no coolant leaks, or smell of coolant in the cabin.
I also feel there must be a hole beneath the wiper cowl possibly. I should look into that aswell. Hmm. This sucks.
Old Feb 8, 2012 | 09:34 PM
caeavesRSX-S's Avatar
There is also an OEM service bulletin.
Old Feb 8, 2012 | 09:35 PM
Old Feb 9, 2012 | 11:48 AM
Frase_civic's Avatar
Had a friend with the same problem and it was a bitch to find the source, he took it through an automatic car wash wish the interior gutted as much as possible and he found the leak... the added soap made finding the entrance point much easier
Old Feb 9, 2012 | 08:07 PM
Where was it leaking?
Old Feb 12, 2012 | 01:23 PM
red Teggie's Avatar
Originally Posted by solbrothers
drill some holes in the floor of your car. problem solved
Old Feb 12, 2012 | 04:06 PM
low91rex's Avatar
Have you checked to see if the heater core is leaking?
Old Feb 13, 2012 | 12:18 AM
PaddyV's Avatar
I will try the carwash suggestion. I smelled the liquid that had leaked in and it smelled nothing like coolant. Definitely water and not the heater core since the heat works quite well.
Old Feb 13, 2012 | 08:22 AM
Couple years back now but im pretty sure it was leak in the cowl area
Old Mar 11, 2012 | 10:39 PM
pogeeboy27's Avatar
In case you are still having that wet passenger floor problem, might want to check the weatherstrips under the cowl. I checked the A/C drain hose and sealed the gaps in the body panels per the TSB. Floor was still wet. I then replaced the corroded weatherstrips on the underside of the cowl. Problem solved. Here's a link to a writeup I found: http://www.team-integra.net/forum/19...placement.html
Old Mar 12, 2012 | 10:42 PM
kingofbattle909's Avatar
hahahahaha...
Old Oct 28, 2015 | 06:58 PM
lurice01's Avatar
10 Year Member
Loved
Community Favorite
i have a 95 civic ex coupe and it has a wet drivers side floorboard only after rainy weather. The more it rains, the more water appears. it appears to be coming in from the clutch master cylinder? i can't really tell and i need help.
to try and fix the leak i have replaced the windshield (it was under warranty from when it broke earlier), and i did that seam sealer thing, too. But i used a different urethane sealer, and i couldnt properly apply the sealant to those really tight areas so i just got as far as i could and used a bunch. (and i never really degreased the area before i sealed it.)
Please help. im frightened and worried.
95CivicHatchMan
Apr 20, 2017 10:43 AM
ripla13
Feb 12, 2011 04:08 PM
jDMbabyx3
May 21, 2008 11:05 AM
LSEGHATCH
Jul 26, 2007 09:49 PM
BrainzIRL
Feb 26, 2006 02:53 AM
