Just did a valve adjustment and now i have a knock 94 RS Stock
Old Jan 10, 2012 | 06:07 PM
Wrona's Avatar
Default Just did a valve adjustment and now i have a knock 94 RS Stock
SO i just did a valve adjustment in this order 1 3 4 2 Exhaust .008 intake .005
i checked all the clearneces each time before turning the motor to the next valve and they were all pretty tight i could get my feeler gauge in there and out with it having a lot of resistance.. i tightened everything down now this happens..
http://www.youtube.com/watch?v=y6PbVW36EDk
im assuming i over tightened the valves or something because it has not done this prior to the adjustment
sorry cellphone camera
Old Jan 10, 2012 | 06:10 PM
TheRealTegger's Avatar
Default Re: Just did a valve adjustment and now i have a knock 94 RS Stock
What method did you use to line up the cams before checking?
If you followed the factory method, you've probably got at least one clearance that's too big. There is a better way...
Old Jan 10, 2012 | 06:14 PM
Wrona's Avatar
Set the motor to TDC
than turn counter clockwise 90 degrees
do that again till the last cylinder
Old Jan 10, 2012 | 06:21 PM
Too iffy.
Try this:
Turn engine so one cylinder's intake lobes and one cylinder's exhaust lobes are pointing straight up to the sky. Check those four and adjust as required.
Turn engine so another pair of cylinder's lobes are pointing straight up. Repeat two more times.
The point is to check the valves that have their lobes pointing directly up to the sky, which will happen every 90-degrees of rotation.
Effectively, you're turning the engine about as much as you are for the factory method, but with this method you're guaranteed to have all the valves OFF the heels of their lobes, which is what you need to do to make sure you're not inadvertently setting excessive clearances.
Old Jan 10, 2012 | 06:24 PM
Wrona's Avatar
Too iffy.
Try this:
sweet bro thank you so much i actually saw this posted somewhere not a while back but didnt pay attention so just to make sure before i do this
lets say i do this will cylinder 1 have all cam lobes up or will it be 1 will have 2 and 4 will have 2 up
Old Jan 10, 2012 | 06:27 PM
bryan24207's Avatar
u guys confuse the **** out of me, im scared to try this now
Old Jan 10, 2012 | 06:37 PM
Another tip: Use a GO/NO-GO system.
As a hypothetical example, suppose your specified clearance is
.008. (of course it will actually be a range, not an absolute figure)
When checking the clearance for that valve, you use
.009 as the NO-GO,
and
.007 as the GO.
You therefore have three leaves of your feelers fanned out for ready access: .007, .008, and .009. (These numbers are not typical of feeler gauges, I'm just using these figures to keep it simple.)
You check the clearance using the .009. The feeler should NOT GO. If it goes, the clearance is too loose.
You check the clearance with the .007. The feeler SHOULD GO. If it won't go, the clearance is too tight.
If .007 GOES and .009 does NOT GO, then you're close enough to spec, and can move to the next valve.
If you find a valve out-of-spec, that's when the .008 comes into play: After setting the clearance using the .008, and torquing the nut to 18 ft lbs, you double-check using the GO/NO-GO feelers.
And so on. This method also saves you the worry of wondering whether you had the right "drag" on the feeler when you set the clearances.
Old Jan 10, 2012 | 06:39 PM
I can't remember right now.
But it's simple. Really.
Just turn the engine while watching the cams, and you'll easily see which ones are coming up and which aren't.
Honestly, once you watch the cam lobes turn, it will be blindingly obvious.
Old Jan 10, 2012 | 06:40 PM
Wrona's Avatar
.009 as the NO-GO,
and
.007 as the GO.
i will try this tomorrow thanks
Old Jan 10, 2012 | 06:41 PM
It reads a lot more complicated than it really is. If you know the right technique, it's a piece of cake.
Old Jan 10, 2012 | 07:00 PM
I just had a look at my feeler gauge set, and I do indeed have a feeler for each .001 below .010. So I do have a .007, .008, and .009. Plus a .006, .005, and .004, etc.
It's one of those things you get so used to looking at that you don't really notice anymore, you know? So I had to double-check.
Old Jan 10, 2012 | 07:22 PM
GagnarTheUnruly's Avatar
There's no reason that the official procedure won't work, as there is plenty of duration at zero lift and a lot of room for error. I've done both a B20 and B18C1 multiple times using the standard procedure and I get very good adjustments. For some reason B18 non-vtec heads seem to be fussy. Did you do it cold, and make sure that the adjuster screws didn't move after you tightened the nuts? It's important to verify the adjustment after you tighten everything down.
Old Jan 10, 2012 | 07:24 PM
DirtyDA9's Avatar
Recheck your clearances, if they are in spec, take the valve cover off, start the engine, find the tickers, and slowly tighten till the ticking stops.
Old Jan 10, 2012 | 07:31 PM
bryan24207's Avatar
not to sound dumb, but u can start ur car without the valve cover on ?????
Old Jan 10, 2012 | 07:34 PM
DirtyDA9's Avatar
yea, the cams will throw a little oil around, but not alot. BMW is a different story, they have a really hard time running with even th oil cap off, PCV has a big role in vacuum with bimmers.
Old Jan 10, 2012 | 07:36 PM
Wrona's Avatar
i checked after i adjusted but i didnt know how much drag i should have some i had more or less than others but ill try what he said the go/nogo tachnique
when i did it on my civic y7 and my H22A i had no problem with it ill redo it tomorrow
Old Jan 10, 2012 | 07:45 PM
If you could get the feeler in, it's over 0.008 and you're just too loose. Sounds like the go/no go technique will fix it.
Old Jan 10, 2012 | 07:48 PM
Wrona's Avatar
alright thanks guys i hope this feels the knocking i know its not a rod because it was fine before
Old Jan 11, 2012 | 02:34 PM
Wrona's Avatar
alright thanks guys i fixed the problem i did the go no go procedure i did it the way TheRealTegger said. I had 2 exhaust 2 intake valves pointing straight up and used a .004 and a .006 to measure the intake .004 went in .006 didn't i knew it was good same with exhaust but i used .007 and .009. Just to make sure I did what DirtyDA9 said to do i started the car with no valvecover and it sounded great no knocking or ticking runs great.
Thanks guys
Old Jan 11, 2012 | 02:41 PM
TOO MUCH TORQUE's Avatar
watch this :
http://www.youtube.com/watch?v=-G_Nq2orpfo
exact same engine being performed on. i believe..THEREALTEGGER is referring to this method. pay attention starting at 3:00 to 3:25
loose better than tight..you dont want a burned valve
Old Jan 11, 2012 | 05:34 PM
Wrona's Avatar
Originally Posted by TOO MUCH TORQUE
watch this :
i already did it.. like i said its fixed
Old Jan 12, 2012 | 03:44 PM
Thanks guys
I love the smell of success!
How many did you find with excessive clearance?
Old Jan 12, 2012 | 06:02 PM
Wrona's Avatar
lol to my surprise i found one that WAS up to spec... im gonna do it this way now on all the b-series i will own
I thought i did it the right way the way i was doing it the cam lobes were facing towards the front of the car not the roof...
but what i did was the go/no go put the .004 it went put the .006 didn't go locked the valve nut and done was done with it in 30 minutes with all of them vs 1 hr and got it wrong
once again thanks
qpzm12
May 14, 2011 07:15 AM
STATek9
Sep 18, 2009 08:47 AM
Ryan15
Oct 5, 2006 07:00 AM
JoseCuervo
Aug 15, 2004 06:30 PM
bocian
Feb 12, 2002 08:40 PM
