ls/vtec or ls build??
Old Jan 10, 2012 | 05:59 PM
2000EKCoupe's Avatar
10 Year Member
Default ls/vtec or ls build??
Just bout an ls motor and want to to a complete rebuild. Ive been researching a lot and im liking the ls build over the ls/vtec. Any suggestions on this? I dont wanna go too crazy just something fun to drive, it would be my dd also. My plans are p30 pistons, shotpeen ls rods, ITR oil pump, t-belt, water pump. All OEM LS bearings? Complete head rebuild also but not too sure yet what valvetrain to use. Any other recomendations please feel free to add. Thanks
Old Jan 10, 2012 | 06:04 PM
LSTurbo23's Avatar
Default Re: ls/vtec or ls build??
LS all motor builds are wastes of time IMHO....the heads are garbage..go LSV...since your tearing the motor apart and building it anyway..LS turbo is also a good idea....
Old Jan 10, 2012 | 06:37 PM
10 Year Member
Really? I haven't heard many bad things about ls heads. Even if I i upgrade th valve train? I'll keep researching also . I aPpreciate your
Old Jan 10, 2012 | 06:38 PM
10 Year Member
Input.
Old Jan 10, 2012 | 06:40 PM
10 Year Member
What ecu would anyone rec. whatever head I use? That what I've been reading. I've been reading a lot of different things
Old Jan 10, 2012 | 07:01 PM
composurey's Avatar
How is a "ls" garbage? your dumb kid.
If you want a daily driver ls, like i do, get a v-tec conversion kit, unless your going turbo, don't turbo a v-tec, your just looking for problems down the road, especially if your wanting a dd. Upgrade the valve terrain, bottom end work, throttle body and intake mani... what else?
Old Jan 10, 2012 | 07:06 PM
10 Year Member
Yea. I was thinking itr valve train if I do go lsv. Thanks again. I don't want anything crazy tho ya know
Old Jan 10, 2012 | 10:04 PM
jdmbennie's Avatar
im doing the same also ppl tell build the ls nd not go lsv n some ppl say lsv but everyone has there own opinion watever works best for you and if you gota budget
Old Jan 10, 2012 | 10:36 PM
jerellduffin's Avatar
Im doing lsv, but like ^^he said, everyone has opinions. Its whatever you want
Old Jan 10, 2012 | 11:01 PM
JTTeG_X's Avatar
what is your goal whp/tq?
if you haven't, suspension upgrades are much more "fun to drive" than engine mods, IMO.
I had both LS turbo and LSV, the turbo set-up was much more "fun to drive". The time and money spent on a LS/V convert. or LS build could be had with a decent turbo kit set-up. You will get MUCH MORE power in the end going boost. I ran mine at 10psi daily driver on stock internals, made 249whp/225ish tq. Even on 7-8 psi would be more safe.
composurey's Avatar
To me, my opinion if your going to be a n/a ls build, LSV just seem's smarter because your getting that higher compression compared to low compression without v tec, but if your going to stay low compression, build the internals and boost the mother****er.
But look at it like this, if your going to turbo your car, you need a good turbo, no ebay! and a good turbo is like 2000-2500$ so instead of a turbo you can spend 500-2000$ on valve terrain and others like bigger intake mani, throttle body, pistons and bottom end work, and still have a pretty damn fast daily driver.
Old Jan 11, 2012 | 03:50 AM
10 Year Member
Hp goal is prolly around 180. I know it's achievable. I'm def not going boost right now. Too much money at this time. Still not 100percent sure yet on my choice. Im in no rush either. Gonna start a build thread when i choose
Old Jan 11, 2012 | 04:56 AM
kyden's Avatar
if you're looking to go all motor, don't even think of an LS head. you'll be starting with a huge handicap.
Old Jan 11, 2012 | 05:00 AM
10 Year Member
Yea. I've read that alot. Lol. I'm gonna go lsv. Definantly. Thanks a lot. Can't wait to start building.
Old Jan 11, 2012 | 05:04 AM
typerturbo29's Avatar
for ecu go for a chipped p28 or a p30 imo
Old Jan 11, 2012 | 05:09 AM
jbpnoman's Avatar
Originally Posted by composurey
...and a good turbo is like 2000-2500$ so...
So, how're the drugs down where you live?
You can get a solid, brand spanking new turbo that will suit your wants for $1100. Alternatively, you can get a busted one for $100, and get it rebuilt for $500. Alternatively again, you can buy a used turbo still in good condition for $400.
If you want to build an NA motor, you're looking at high compression pistons, upgraded rods, and a fair bit of headwork. Parts and labor costs later, you'll have more power piecing together a turbo kit.
If you're truly wanting to go NA, start with pistons, rods, and a knifed crank, then worry about your headwork. Get a chipped ECU, and get it tuned. If you don't want to get your hands dirty, and you live on the east or west coast, look into talking to Darton. Last time I spoke with them, they quoted me just over $3000 for a fully built motor, to your specs.
Old Jan 11, 2012 | 07:43 AM
Red_Army's Avatar
....wow...
ls/v turbo. why not get both? the rod/rod bolts are the biggest points of failures in LS. since your tearing it all apart anyways why not put in new better everything. no reason you can't boost an LS/V.
use the ECU from the head. it won't matter much because you'll have to get a custom tune for it anyways.
but since you only need/want 180 an NA lSV will easily get to that. but lets not forget torque is the real mover.
Old Jan 11, 2012 | 08:40 AM
Tylermiller888's Avatar
I think you missed the part where the dude only wanted 180 to the wheels.
That's a tuned bolt-on LS/Vtec, or at worst, one with a small cam. Definietly don't need to port'n'polish, pistons, and etc.
@OP
You should strive for:
LS Block
ARP rod bolts
Shotpeen LS Rods
Pr3 pistons
ARP Headstuds
Headgasket of your choice
GSR/B16a Head
Valvetrain of your choice
Stage 1 cam of your choice
Intake Mani
A OEM throttle body port-matched will probably do you for this setup
and some sort of CAI
Hell, that setup is simple, reliable, and not to costly
And you can also do what I did, and get a Phearable ECU to get it tuned.
Alot of people dog on them, but there's several around here in cars that get beat on, on a day to day basis, and they have yet to fail.
Old Jan 11, 2012 | 08:48 AM
10 Year Member
Thanks for some of the ideas. Helps alot. I'll keep lookin into what I wanna bolt up. Doin it right the first time
Old Jan 11, 2012 | 11:01 AM
Also stay on the look out for a not LS tranny (GSR, B16a, Type R, etc)
You'd be surprised just how much fun a car gets with a better geared tranny.
Old Jan 11, 2012 | 11:19 AM
10 Year Member
Absolutely
Old Jan 11, 2012 | 05:31 PM
10 Year Member
picked up my motor today and looks clean, gonna tear it down this weekend to get a better look at it. im gonna post pics. then ill go from there
Old Jan 29, 2012 | 08:55 AM
LSTurbo23's Avatar
Lmao...valve terrain? And im the dumb one? I said the HEADS are garbage...learn to read "kid"
Old Jan 29, 2012 | 09:39 AM
10 Year Member
Lol
Old Jan 29, 2012 | 09:55 AM
DirtyDA9's Avatar
If you are not boosting the LS, go with the LSV.
