93 ej2 coupe wont get spark
i have a 93 ej2 coupe and it wont get any spark. I have replaced the ecu, distributor, cap and rotor, main ignition relay, plugs, wires, fuses, and checked all the grounds but still wont fire. any suggestions on fixing the prob would be great.
Does the fuel pump prime?
Any CEL codes?
Is the timing belt snapped?
Does the Blk/Yel wire attached to the coil have battery voltage with the key in ON(II)?
Have you resistance tested the coil?
Has an auto parts store tested the igniter unit?
Any CEL codes?
Philippines03j
Aug 24, 2021 08:26 PM
