Block d16y7, head p2a, intake p08, ECU p05 and p06 - Is this stuff compatible?
Someone please help me out! Im lost on what to do with this motor! I think the guy i got the car from just slapped this together to make it run and sold it.
My block is d16y7
the head is p2a
intake is p08
and i have a p05 and p06 ecu
Can this stuff go together and what ecu should i be using if it can? Or should i start lookin for a head, intake, harness, ecu or should i just get everything? Like i said .... Im lost here
My block is d16y7
the head is p2a
intake is p08
it runs but its a turd! im just tryin to figure out what i should have so i can get it running right. as of now when it idles it revs up to like 3000 rpm then down constantly. its not as bad once it warms up but somethings just not right.
note taken on the thread title btw. guess i shoulda been more specific
Thread titles MUST summarize the tech problem so that members browsing titles can easily understand the problem without reading the post -- Title edited.
My block is d16y7
the head is p2a
intake is p08
My block is d16y7
the head is p2a
intake is p08
Base mechanical timing is off with ecu by half a tooth, fuel and timing maps are super off which makes you slower. and also no vtec.
obd1 use a chipped p28 w/ y8 fuel and timing maps
obd2 use according ecu d16y8 - p2 p2p or find a obd2 p28 from del sol
killer6993
11
Dec 7, 2011 11:45 PM
FaNiO
Oct 20, 2009 09:41 PM
jjbonseye
Mar 18, 2006 08:41 PM
civicracer1993
Feb 8, 2003 03:53 PM
