Del Sol fron lip: which lip is that?
Old Jan 9, 2012 | 12:22 PM
tonyjdm's Avatar
Default Del Sol fron lip: which lip is that?
I think it should be the oem civic 99-00 front lip, isn't it?
it need some modifications to fit or will fit plug and play?
it will fit the EG backyard special lip without modification?
thanks
Old Jan 9, 2012 | 12:23 PM
kaiba's Avatar
Default Re: Del Sol fron lip: which lip is that?
Type R style
Old Jan 9, 2012 | 12:39 PM
motegicivic's Avatar
Check ebay, for a replica style, prob too much work to get a 99 lip to fit.
http://www.ebay.com/itm/93-94-95-96-...item20c1128789
Old Jan 9, 2012 | 12:46 PM
tonyjdm's Avatar
the type R style is totally different, they are a lot more "hard" in the corners!
Floeh6's Avatar
Originally Posted by kaiba
Type R style
+1
Same as this one
Old Jan 9, 2012 | 01:27 PM
delsolo95's Avatar
came from 99-00 civic si usdm, type r civics edm and jdm
Old Jan 9, 2012 | 01:43 PM
MonkeyBoy668's Avatar
Back when I was thinking about buying one, it was a 99-00 Civic Si lip, and they are an ungodly &*(@#$&*(#$ bastard to fit onto a Del Sol. You basically have to stretch the plastic into the correct shape, which is about as much fun as it sounds.
I second the recommendation to just buy an replica lip off eBay for a Sol, it's got to be easier than making the OEM solution work (assuming you can still buy OEM).
Old Jan 9, 2012 | 01:51 PM
delsolo95's Avatar
op get an eg6 lip looks way better than the usdm si or jdm civic R lip
Old Jan 9, 2012 | 04:14 PM
That one pictured is more like a domestic 99-00 si. Sometimes the say the generic term type r.
I think the ctr (real jdm) is a real type R
Old Jan 10, 2012 | 03:24 AM
Floeh6's Avatar
I have an eg6 lip on my delsol, it looks great and is not really difficult to install however I had to drill my bumper
Old Jan 10, 2012 | 09:42 AM
96DelSol's Avatar
99-00 Si lip is easy to fit on 93-95 you will just end up with small gaps on corners.
delsoldriva
Jan 11, 2008 12:30 PM
mrtrinh
Nov 16, 2006 08:25 AM
mengniu2003
Sep 19, 2006 12:45 PM
nighthawkgsr
Jan 6, 2006 07:36 PM
Bruce Leeroy
13
Jun 14, 2004 11:06 AM
