How can i block off the egt fitting safely?
Old Oct 8, 2002 | 01:47 PM
blufke's Avatar
Default How can i block off the egt fitting safely?
exactly what the subject says. i bought my maxrev manifold with the egt probe fitting already jbwelded and tightly put on, but now i dont need an egt(going with wideband a/f). what is a good way to plug it?
Old Oct 8, 2002 | 02:26 PM
DeepSi's Avatar
Default Re: How can i block off the egt fitting safely? (blufke)
I had an egt fitting on my downpipe from the previous owner, i went to the local auto store and got a bolt that went in and sealed it up for now. i plan to get a wideband soon and just might use the same bung.
-deepsi
Old Oct 8, 2002 | 02:35 PM
Foozball26's Avatar
Default Re: How can i block off the egt fitting safely? (DeepSi)
I would think the best way would be to get a piece of metal welded on.
[Modified by foozball-26, 5:35 PM 10/8/2002]
Old Oct 8, 2002 | 02:54 PM
blufke's Avatar
Default Re: How can i block off the egt fitting safely? (foozball-26)
id prefer not to weld it closed. bolt sounds like it might work. but i dont want it to get permanently stuck in there. other suggestions?
Old Oct 8, 2002 | 07:22 PM
blufke's Avatar
up
Old Oct 8, 2002 | 07:36 PM
BoostedH23a1's Avatar
use a toothpick. aha
i would use a bolt and put some antisieze on it. (comes in a can thats says AntiSeize, its silver works pretty good...
Igotthe_Murder
Oct 21, 2007 06:44 PM
14bcoupe
Nov 20, 2004 04:15 PM
KaoticSnow
17
Aug 22, 2004 12:40 AM
93preludes
Dec 4, 2003 01:58 PM
DragII
Jan 3, 2002 02:10 PM
