LSV problems, please help
Hey guys so the other day I started my car and for some reason I decided to pull off the spark plug wires one by one, after the third spark plug the car shut off and now it wont start, I already tried checked the fuses and changed the ignition coil and still won't start, so i tried a different dizzy that worked and it won't start idk what to do any more please help,bob and the car is getting spark and fuel so.... Idk
Why were you disconnecting the wires one by one knowing that by the third it was gonna stall. Did you think a car can run on one cylinder? lol Just kiddin. How do you know you have spark? Did you check for spark at ALL 4 cylinders? White/blueish arc=strong spark, orange/yellow arc=weak spark.
I doubt messing with dist. wires would cause no fuel/air/compression, so obvioulsy it's something in the ignition, so did you varify spark at each plug?
idk what the hell i was doing but i used a screw driver and checked the spark on all the cylinders, and i also cleaned the spark plugs. should i buy new ones??? it sounds like it wants to turn on but idk what else to do
anht
13
May 1, 2010 11:57 AM
e jay one
Mar 4, 2006 06:02 PM
