New B18 Swap No Spark
Old Jan 9, 2012 | 05:47 AM
whited's Avatar
CRX God
Default New B18 Swap No Spark
I just installed a B18C R in my CRX. I am not getting spark.
I have a new Cap, Rotor, Plugs, and Wires. So that should limit it too, ECU, Distributor and Wiring. I think the crank position sensor is in the distributor, on this. I am guessing the ECU and Distributor is under warranty. So I was going to do a pin to pin test from the ECU to the Distributor and then contact the place I got the engine.
My question is, which would you replace first? The $150 distributor, or the $150 ECU?
I do have my build in another thread, but wanted to post this question in a new thread.
Old Jan 9, 2012 | 05:50 AM
whited's Avatar
CRX God
Default Re: New B18 Swap No Spark
More info.
I used the CRX injectors with the resistor box, and I do have fuel pressure. I also used Rywire jumper harness to the OBD2 distributor. The OBD2 ECU is a p73.
Old Jan 9, 2012 | 06:30 AM
crx_si-r's Avatar
you do realize that on obd2 motors there are separate crank angle sensors actually located on the engine by the oil pump. did you also wire those in?
also you didn't post if you have any check engine lights? also i don't remember exactly which year, but most P73 ecu's are equipped with immobilizers, where i think you need a chipped key in order to power the ecu.
Old Jan 9, 2012 | 06:38 AM
whited's Avatar
CRX God
Are you sure the JDM one has a crank angle sensor? There was 2 plugs on the back of the motor block. The knock, and another one wire sensor, which the rywire harness had.
The check engine light was 6, I am guessing that was for the temp sensor.
Chipped key?
Old Jan 9, 2012 | 02:10 PM
JDMNUTZ's Avatar
check this link
http://techauto.awardspace.com/ignition.html
Old Jan 9, 2012 | 02:17 PM
gratua's Avatar
chipped key, meaning it has a micro chip in it that communicates to the car to actually work
Old Jan 9, 2012 | 02:27 PM
whited's Avatar
CRX God
Didn't know about this. Is there anything I can do to make the p73 work in the CRX?
Old Jan 10, 2012 | 04:34 AM
whited's Avatar
CRX God
http://b16a2.kicks-***.net/automotiv...mmo-remove.htm
Old Jan 10, 2012 | 10:12 PM
whited's Avatar
CRX God
You had me convinced it was the immobolization, but the ecu was missing the immo chip.
I am guess I am going to to have to check the distributor. It is late haven't looked it up yet, pictured is the number on it.
Old Jan 10, 2012 | 10:16 PM
crx_si-r's Avatar
i see the problem right there on the last picture. are you using an obd0 distributor on with an obd2 ecu?
Old Jan 10, 2012 | 10:42 PM
whited's Avatar
CRX God
It was what came on the engine, and the obd0 to obd2 conversion from Rywire plugs into it.
What makes you think it is obd0?
Old Jan 10, 2012 | 10:53 PM
crx_si-r's Avatar
the white round plug in the back ground of the last pic
Old Jan 11, 2012 | 03:38 AM
whited's Avatar
CRX God
No that is the adapter to obd0.
Old Jan 11, 2012 | 05:48 AM
crx_si-r's Avatar
Pop open the distributor and make sure you still have the spring attached to the ignition coil
Old Jan 11, 2012 | 06:07 AM
whited's Avatar
CRX God
Yeah it is still there.
Angeljavier3577
Apr 30, 2018 01:41 PM
jdmeg1075
May 22, 2008 03:52 PM
simplypinoyy
Oct 14, 2004 07:09 AM
ejprimo
Apr 25, 2003 10:20 AM
