throttle response problem...any ideas?
Old Jan 8, 2012 | 06:11 PM
jarhead90crx's Avatar
Default throttle response problem...any ideas?
90 crx si
Obd0 b18b1
Obd0 pr4 ecu
When the tach gets between 3-3500 rpms the engine power surges down. Lights don't dim or anything, I just lose power for a split second. It happens every few seconds when the tach is between 3-3500 rpm like clockwork. It doesn't do it when the tach is in the other ranges (if it does it isn't noticeable) Car idles funny too but it starts and runs fine other than that
Any ideas?
Old Jan 8, 2012 | 06:12 PM
Dc4LsTeG's Avatar
EK9
Default Re: throttle response problem...any ideas?
Any cels?
Old Jan 8, 2012 | 06:45 PM
The check engine light is on but I was told it would be on with this motor swap until I had the ecu chipped? Somethin bout a knock sensor that has nowhere to hook up to?
Old Jan 8, 2012 | 07:15 PM
acmoc's Avatar
What engine?
Sounds like iming is off, ignition timing
Old Jan 8, 2012 | 07:22 PM
B18b1 out of a 95 teg. I converted it to obd0
Old Jan 8, 2012 | 07:28 PM
bmxtrev's Avatar
sounds like you have a loose wire, or your IACV isnt working. when you swap the orange and white wire, if one of them isnt making a connection you'll be in limp mode.
IACV not working will give you a two-step type hesitation around 3k rpm. Ive had both of these problems, check your wiring and IACV
Old Jan 8, 2012 | 07:39 PM
codybuRr's Avatar
yea, there's no knock sensor or any bullshit like that.
you can convert the LS motors up and down no problem.
its just adding and taking away sensors.
there's just messed up wiring somewhere
Old Jan 8, 2012 | 07:43 PM
bmxtrev's Avatar
can you tell us if you're in limp mode?
what are the codes being thrown?
Sweet ill check on my wiring and iacv. Thanks a lot!
If anyone else has other ideas, thoughts, input feel free....
Old Jan 8, 2012 | 07:58 PM
Honestly I wouldn't know how to tell if I was in limp mode and I don't have a code reader so I hav no clue what codes are being thrown. Kinda low on cash at the moment so I haven't been able to take it in to have a diagnostic done. Figured this was a good place to start in case it was somethin I could do myself. Up to this point I've done everything to the car myself except the harness conversion and machine work
Whereabouts is the knock sensor or lack of? Is there a way to fix the knock sensor code myself or is it ecu programming?
Old Jan 8, 2012 | 08:03 PM
bmxtrev's Avatar
If you try to rev up slowly in neutral and it gets stuck around 3k rpm and fluctuates like a slow two-step, thats IACV.
If you are in limp mode (loose wire), you will not be able to get above 3500 rpms no matter what. IACV you can get past 3000 rpm by applying a little more throttle.
Old Jan 8, 2012 | 09:01 PM
I know I can go above 3500 but ill have to check the neutral rev tomorrow
Old Jan 8, 2012 | 09:29 PM
uberEFtuner's Avatar
It could be a bad distributor too. But you need to get the check engine codes.
Old Jan 9, 2012 | 12:09 AM
Spug's Avatar
It's obd0, it doesn't get scanned for codes. Turn the key to the ON position and count the blinks of the red LED on the ECU.
Old Jan 9, 2012 | 04:17 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
All of this talk is non-sense until you read the codes!!! Just stop already... Do as stated above.
Old Jan 9, 2012 | 11:53 AM
Dc4LsTeG's Avatar
EK9
X2 all these threads on h-t where people want help but they won't even check their codes
halocorp
Jul 22, 2010 06:44 PM
ramco
Mar 6, 2010 07:30 PM
93egallmotor
May 15, 2007 04:52 PM
GsrTurboCRX88
Mar 20, 2006 03:18 PM
OneThirtyEight
Jan 10, 2005 06:05 AM
