Suspension & Brakes Theory, alignment, spring rates....
Problem Assembling Pro Springs and Pro Dampers for EK
Old Jan 8, 2012 | 05:35 PM
civicmanyep's Avatar
Default Problem Assembling Pro Springs and Pro Dampers for EK
When I assembled the pro springs w/ the pro damper it was actually longer than the stock spring and shock so it won't fit when I try to put it in the car.
Any tips?
Old Jan 8, 2012 | 06:14 PM
grumblemarc's Avatar
The Grumpiest
Default Re: Problem Assembling Pro Springs and Pro Dampers for EK
Pro whats? Hazarding a guess due to your incredible lack of information, I'd say you have the wrong springs.
Old Jan 8, 2012 | 06:16 PM
eibach pro springs and eibach pro damper
Old Jan 8, 2012 | 06:44 PM
The Grumpiest
If it's the kit I'm looking at,
http://www.tirerack.com/suspension/s...ystem+Plus+Kit (minus the sway bars)
aren't you supposed to use a spring compressor on those? And if not then I'd say you got the wrong springs. Call the retailer you got them from.
Old Jan 8, 2012 | 06:47 PM
The Grumpiest
Or are they these?
http://performance-suspension.eibach...tem__step_1_3_
Provide a link or pic. Some of us don't have every suspension component memorized.
Old Jan 8, 2012 | 06:54 PM
I picked up the autozone spring compressors and they are complete crap. I took the stock springs apart without it. You think I need a spring compressor to get it small enough to fit?
Old Jan 8, 2012 | 07:08 PM
I bought these.
http://www.autoanything.com/suspensi...A2549A0A0.aspx
http://www.autoanything.com/suspensi...A2547A0A0.aspx
Old Jan 8, 2012 | 07:10 PM
I bought the ones you found off tirerack.
Old Jan 8, 2012 | 08:59 PM
90_EX_Civic's Avatar
you can do it a ghetto way and compress the spring/shock when it's on the car.
Old Jan 10, 2012 | 12:00 PM
wmac's Avatar
i have done this
OP, either those springs are extra smooshy, or you will have 4x4 status
ep3brandon
Honda S2000
14
Feb 10, 2011 11:07 AM
raffaelli
Suspension & Brakes
Aug 7, 2008 06:13 AM
EK4nut
Suspension & Brakes
Jun 13, 2007 02:51 PM
janz3n
Mar 23, 2007 04:27 PM
vincepru
Suspension & Brakes
12
Oct 14, 2005 10:48 AM
