EG/D16Z6 sounds like a Subaru WRX STi!!
im having this problem but mine isint the exhaust or injectors..it has diff injectors and its on a whole diff car..when i hit 5k rpms its realy loud and it picks up speed realy slow..also changed the spark plug wires n nothing so if anybody can help me out..oh and that started happening after i changed my timing but i have messed with the timming 2 times n still same problem so idk wat else to do
Have you checked the cap and rotor? Do you have an exhaust leak?
You MUST provide all pertinent information about your car and engine. Failure to do so may result in thread closure.
Another thing you might want to check into is the o2 sensors. I believe there is one under the hood and on the exhaust pipe itself. Back in the day I had an old pos pontiac that had the exact same problem and it turned out to be a simple o2 sensor.
Do you have an idea as to where the "loud" is coming from? Does it sound like it's coming from under the hood or under the car?
ok sorry dis my first time doing writin on a forum llol..ok is a d16z6 low comp dont know wat internals it has the engine ran great beat high comp z6 boosted z6 it was a strong engine but now its loud like wen u floor it it sounds loud but not going anywhere n at 4000rpms it picks up the rpms real slow like if its getting forsed ..i had the engine on my car den i changed the timing belt and thats wen the sound started the sound comes from under the hood by da throttle body..i know its not a exhaust leak because i sold the engine to my friend n its doing the same sound on his car... have noy checked cap or rotor or o2 sensor n its not miss firing it sounds good indles good...oh n its on n eg
the engine was built by a friend of mine n he built it a tooth advanced but we i took it to anoder friend dat knows bout timing n wen i took it to him i was off by 3 teeth n it still turned on n sounded good...he put it right on timing well advanced one tooth like my friend dat built it told me to..but yea ill check the compression on it
If the motor wasn't built to OEM spec and needs to be one tooth forward to run right, then we're going to need a lot more information before we can help you diagnose a problem. You have two options here. Option one is to hunt down the guy who built the motor and have him figure the problem out, since he's probably the only person who knows the specs. Option two is to set everything to OEM specs and work from there, and we can try to help you.
The reason people aren't understanding you is because you're typing in Ebonics. It might not be how you speak, but typing in proper English makes forums much easier to use. Sentences, paragraphs, and punctuation makes life in text a LOT easier.
I'm just spitballin here but if it were a timing and/or compression issue wouldn't it idle really rough? I don't have enough knowledge to know for sure but I always thought if it were one of those two problems you'd have an issue with it whether you are in neutral at a full stop to driving down the freeway. Just a thought.
Also what is the reason he wants you to set cam timing advanced without an adjustable cam gear? No reason the timing should be intentionally a tooth off.
thats the weard thing is if i go back a tooth it turns on the same n runs the same so you cant realy tell if your right on timing..the engine also has a built head diffrent cams...he told me a reason why he built it a tooth advance but i dont realy remember i belive it had something to do with him boosting it n easy tunning but not 100% sure thats the reason....im going to check compression n change the sprk plugs and see wat dat does
See this is why when I bought my civic I was REALLY wary of people who had "swapped engines". There's nothing wrong with it in theory but when you're buying a car like that with no knowledge or paper trail of what's been done it's even hard to fix the problem. The only reason I bought mine with a swapped engine(even though it wasn't the swap I initially wanted) was because the guy had all the work professionally done and had a paper trail for EVERYTHING. I also did as much research as I could before I bought it. Whatever the problem may be I hope you get it fixed.
even if you get paper dosent mean that wat he put in the engine your buying..i can built my engine and give the paper work to a friend dat has the same engine and say its built..so paperwork dosent mean much to me..the engine was running fine befor i didnt buy just the swap i bought it on a running car
dude can u please learn how to spell? Use punctuation? It is so hard to understand what you are saying my head hurts from what I have read here "weird" is spelled like that not "werd" seriously the USA has public schools that you probably have gone to if you are from here and it gives you no excuse to sound like this.
Set you timing to spec use a timing gun and set ignition timing as well pull any cels
sorry **** i didnt know i had to spell evrything right..its not my fault ur head hurt..yea i know im not the best speller..i need help with my car not ppl telling i cant spell..ive gone to other forums and they spell worse than me..as long as u know wat im saying thats all that matters to me. if u dont have anything to say bout my question then dont day nothing..if u dont like the way i spell dont dont read my post
