hondata s300 problem the engine not start help
hi i have a problem with my s300 and the car does not start
i have a civic sir 92-95 b16a2 itb all motor
my ecu is edm p30
i run smanager 1.5.4 software
the car is all motor itb b16a2 and the following message is my problem thanks please help
i run my engine to set the a/f r for idle
some times the software through me out and says off line
and i try to datalog and i can not sometimes the datalog button pressed but when i press record no record values are write in the recorder af/r values table
then i try to read with datalog my tps and when i push the datalogg 2 or e different times it shows me different values
when i stop the engine and i try to start it again never start
i try to set a built in calibration for itb but the engine does not start
,the car does not throught any check engine so my ecu is right
i think and i belive is from hondata i do not see if the light at usb point is red or green
if i have problem with s300 the light must be red ?or maybe still is green and i have problem?
my tuner ask me if i try to datalog with my pc at power and i say yes is that the reason?
the pc when i try to connect must not be at the power sypply??? thanks please help me how to find my problem
my ecu is edm p30
captain_sl0w
Jul 20, 2008 05:42 PM
