compound boost CTSV build.
Old Jan 7, 2012 | 09:17 PM
russianvr4's Avatar
OG Fabricator
Default compound boost CTSV build.
car is an 09 pearl white CTSV with 8k miles on it. belongs to my shop neighbor, prior to the build he ran 10.4@132 at 620whp with basic boltons. Goal is low 9's at 15x mph.
twin PTE BB 6766's
46mm gates
tial bov
a/w IC using an aftermarket heat exchanger and ice box
once im done with the turbo setup, its getting ID2000's and bigger pumps installed along with a 427 and a built trans. should be a hell of a sleeper!
using stock mufflers for daily driving, will build straight pipes for track use.
Old Jan 7, 2012 | 11:08 PM
FabChild's Avatar
Default Re: compound boost CTSV build.
looks like a tight fit, good job
Old Jan 8, 2012 | 05:33 AM
russianvr4's Avatar
OG Fabricator
Originally Posted by FOBrudy
Thought you stop working on car and switch to industrial welding?
You looking for help at your shop?
i actually do have a job at www.dancargroup.com that i work at full time. i still have the shop but its a hobby/after hrs kinda thing now. i am starting to enjoy it again now that i am not stressed out all the time. i am now able to pick and choose what i work on and who i deal with, and thats HUGE for me. i got sick and tired of dealing with ********* that are out there, they ruined my desire to do car stuff for awhile.
Old Jan 8, 2012 | 06:29 AM
ToxicFabrication's Avatar
OG Fabricator
Looks good Russian!
Old Jan 8, 2012 | 06:34 AM
scartail's Avatar
Looks awesome! Just curious, why is it called "compound"?
Old Jan 8, 2012 | 06:38 AM
russianvr4's Avatar
OG Fabricator
the car is utilizing a factory supercharger and we're adding turbos on top of that, so 2 power adders which 'compound' the air pressure.
Thanks Collin!
Old Jan 8, 2012 | 06:46 AM
all_motor_mike's Avatar
I call it twin charging..... Where do u find all theses high end cars to work on?
Mike
Old Jan 8, 2012 | 06:51 AM
russianvr4's Avatar
OG Fabricator
connections my friend. i go out of my way to talk to people, make friends, help them out etc. granted it doesnt always work, sometimes you'll meet ********* that will **** you over like i've gotten before, but with some experience/practice you can tell them apart. this car i got lucky, he's my neighbor in the business complex, saw all the work i've been doing and dropped it off with cash in hand to get the build going.
Old Jan 8, 2012 | 08:11 AM
builtboosted's Avatar
how is the drain going to work out on that? cant drain up. Looks really good though
Old Jan 8, 2012 | 09:08 AM
TurboFocus's Avatar
easy solution, A pump
Old Jan 8, 2012 | 03:10 PM
atutt's Avatar
Mike
That's because it's actually called twin charging..
Compound turbos are set up like this.
Small turbo feeds a larger turbo. At x amount of boost the gas bypasses the small turbo and runs on the larger turbo.
These setups are HUGE in the diesel truck world.
Old Jan 8, 2012 | 03:36 PM
Andrew Marquis's Avatar
^ not all compound turbo setups bypass the smaller turbo.
CTSV looks sick! Are there any other photos or updates?
Old Jan 8, 2012 | 06:47 PM
russianvr4's Avatar
OG Fabricator
check the thread title, i never said compound turbo. compound boost /=compound turbo. i am quite familiar with both
Old Jan 8, 2012 | 10:13 PM
fastrabbit's Avatar
killer build... I'm watching this one..
Old Jan 8, 2012 | 10:20 PM
FOBrudy's Avatar
Its nice to hear your doing ok..your work is top notch!
Your work place have any openings?
Old Jan 9, 2012 | 03:30 AM
HellaFab's Avatar
My only question was the oil drain and the pump setup.
That i would love to see.
Great work!
Old Jan 9, 2012 | 04:33 AM
weiRtech's Avatar
OG Fabricator
looks good, make sure you add some beads on that i/c!
Old Jan 9, 2012 | 07:19 AM
russianvr4's Avatar
OG Fabricator
thanks, im not sure about that right now.
Old Jan 9, 2012 | 07:39 AM
russianvr4's Avatar
OG Fabricator
Great work!
i'll def post it up when im done, but the idea is to build a small 'sump' tank that the oil drain lines will go to, from there, the pump will suck the oil and return it into the pan. pretty straight forward.
Old Jan 9, 2012 | 02:39 PM
markspan6243's Avatar
Flattery Will Get You Everywhere
video???
Old Jan 9, 2012 | 05:24 PM
MidShipCivic's Avatar
This is called Step TurboCharging.
That is not compounding, compounding is something that puts power back into the engine.
As for blowing into a supercharger you could almost call it compounding but it's driven by a belt how could that ever transfer power back into the engine that's not such a nice way to use power transmission (use of belts).
Twin charging? That like saying ''twin turbo'' differently what exactly is twin when you're doing that... you could say ''Dual Charged''
Old Jan 9, 2012 | 06:09 PM
russianvr4's Avatar
OG Fabricator
Originally Posted by markspan6243
video???
its not running yet, got a few little things to finish up.
Old Jan 10, 2012 | 02:09 PM
Smokinsax's Avatar
The Boot
why would you not call it "triple charged"?
Old Jan 10, 2012 | 06:30 PM
TurboFocus's Avatar
WHO CARES WHAT THE CORRECT TERM IS, this is a fab forum.
Old Jan 10, 2012 | 06:36 PM
Smokinsax's Avatar
The Boot
its also a tech forum...
