im stuck on the side of the road with a code 6 15 43
Old Jan 7, 2012 | 02:49 PM
xwhitchx's Avatar
Default im stuck on the side of the road with a code 6 15 43
All of this happen and my car will not start. It killed the car when I was driving. So I waited and the car turned back on. I could drive it half a mile or so and it will die and give me the same codes. Idk what to do to fix this.
Old Jan 7, 2012 | 02:52 PM
Former User's Avatar
Default Re: im stuck on the side of the road with a code 6 15 43
If you reset the ECU (remove 7.5A hood Back Up fuse for 3 minutes or more), do all three codes repeat after cranking the engine for 30 seconds? In general, only code 15 would prevent the engine from starting.
Old Jan 7, 2012 | 03:32 PM
xwhitchx's Avatar
I only have code 15 now. It seems to be the dizzy. I put a friends in and the car works just fine.
Old Jan 7, 2012 | 03:41 PM
The igniter unit/ICM is generally the cause of code 15.
civicboy420
Sep 25, 2011 06:05 PM
jmeyer99
Aug 2, 2007 10:18 PM
BeezInACan
Oct 20, 2006 08:00 AM
crx(gator)
Apr 27, 2002 03:51 PM
