B18c1 power question
I have a B18c1 engine mods.
•Weisco 12:1 pistons
•Password Power Chamber Intake
•4-1 Itr Replica Header
•2.5in Exhaust
•Hi flow cat
•Blox B cams
•Supertech spring
•Aem adj cam gears
•p28 with Hondata
What would be my power output with this set up I've been looking n can't seem to find a build that seems close
•2.5in Exhaust
•Hi flow cat
•Blox B cams
•Supertech spring
•Aem adj cam gears
•p28 with Hondata
Can't answer that. time to take it to the dyno and find out. Any "numbers" you get are going to be purely speculative based on what they've seen on X-type of dyno..
You should have at least a general idea or you wouldn't have purchased the parts you did, even if it was based upon a bandwagon, a friend, or other testimony, right?
But good luck.. keep it breezy.
Right well I bought the motor for like 500 n trade for n ls longblock n didn't know what was don't in the motor until we opened it up to change out the headgasket cuz we knew it leaked after the first start up. So we discovered the built motor n he gave me a ball park number of around 200+ but I'm wondering n it will most likely be put on a dyno jet
TwistedHatch
18
Sep 8, 2004 01:56 PM
