should i replace t-stat housing??
Old Jan 7, 2012 | 02:05 PM
pliskin8's Avatar
Default should i replace t-stat housing??
i replaced my thermostat with an oem honda one a couple of weeks ago because I found a leak on the bottom side of the housing, i noticed the coolant reservoir was a little low so i checked again for any leaks and it's back in the exact same spot, do i need to replace the whole thermostat housing or is there anything else that i should do
Old Jan 7, 2012 | 02:16 PM
Dontoh's Avatar
Default Re: should i replace t-stat housing??
should be replaced.. too much pressure to try and cob that one with rtv gaskets or anything.. might as well do it right ya know
Old Jan 7, 2012 | 02:18 PM
Former User's Avatar
It's easy to install the thermostat rubber seals incorrectly. Check that. Also be sure to torque the bolts to spec.
Old Jan 7, 2012 | 02:38 PM
pliskin8's Avatar
allright, i dont have time today but i'll take it apart tomorrow and check everything
Old Jan 7, 2012 | 02:53 PM
motegicivic's Avatar
You can also try some rtv, or honda bond, they sell permatex sealant at advance auto. Check the housing it self for cracks.
Old Jan 7, 2012 | 03:07 PM
pliskin8's Avatar
i actually did use hondabond when i changed it but i will check for cracks 'cause i'm thinking that might be a possibility
Old Jan 7, 2012 | 03:33 PM
The housing is not too expensive. Do you think it was over torqued at one point, typically thermostats are not changed too often.
Old Jan 7, 2012 | 03:51 PM
pliskin8's Avatar
it's possible, i've only had the car for a year and a half so i dont know what the previous owners did
jermie_jrmz
Honda Civic (2001 - 2005)
Mar 9, 2015 04:15 PM
keico
Honda CR-V & Element
Mar 1, 2013 05:43 PM
bb4socal
Nov 23, 2007 08:01 AM
^jefs0ng
Oct 8, 2003 10:09 PM
