How do I do a compression test?
Hey guys,
I just did a compression test but my numbers came out really low. Not sure If I did it right or if my engine is bad
I'm thinking the first one because the engine runs really good.
I got these numbers
sohc zc
1 155 2 150 3 158 4 160
Heres what I did
Warmed up engine
removed all spark plugs
removed ecu fuse
threaded compresion tester in two three threads only (was afraid it would get stuck
with gas pedal on the floor I cranked the engine for about 4-5 secs each
Theres a small adapter that comes with the tester but I didn't know If I needed it because the hose threaded into the holes without it
I did the test because I thought I had a bent valve.
after I set the timing on the car I hear a small valve tick type noise
One last question; If one of my valves was bent I would have no compression correct?
I got these numbers
sohc zc
Heres what I did
Warmed up engine
removed ecu fuse
Looks like you did everything right and the numbers aren't to far apart, some compression testers read low, do you have a diff one you can try?your mainly looking for a big difference between cylinders
I did a comprression test with a tester from a different store (renting the testers) when I first put the motor in. All the readings were basically the same.
I found this diy on google
http://www.superhonda.com/forum/f55/...n-test-124194/
I had none of those symptoms that made me put oil into the holes or proceed to a leak down.
Just curious of that noise it makes now that I set the ignition timing
Maybe I'm just paranoid
idles smooth
What is a wet test?
idles smooth
What is a wet test?
make sure to use the adapters to get the true readings, they are in the kit to give you the proper clearances to perforn the test
Compression numbers are tolerable. On the low side but usable (from what I can remember).
If you had a bent valve you would have really really low numbers on that cylinder.
A wet test will seal the piston rings, so if your numbers don't increase you have an issue somewhere else. Numbers should increase with a wet test.
Checking your valve lash doesn't take long, I would personally check over it.
All of your spark plugs look good?
yep all my plugs are good.
I actually checked my lug nuts and they were a bit loose.
It is a similar sound to that so I hop thats what it is, the sound is only when moving from a stop. not when I rev it in neutral
Just to confirm you need to remove all the spark plugs before doing one cylinder?
I seem to remember friends having done them one at a time but I could be wrong.
If someone could confirm either way That'd be great,Thanks,Matt.
if you did in fact get it tight and those were your readings in the cylinders at WOT, then i would say that it shows the wear on your motor for its age but its certainly not horrible.
redef90si:
all plugs out or one at a time, doesnt matter, the only affect is that the crankshaft will turn over somewhat easier because the other 3 cylinders are not compressing air in the combustion chamber since the absense of the plugs allows the air to escape.
try turning the motor over with at the crank pully with a wrench, now take the plugs out and turn it, you WILL see the difference. (or feel it rather)
Adjusting Valve clearance is a very good way to quiet down noisey valve ticking, the excessive clearance allows for more travel before the rocker strikes the valve, hence the noise.
Checking valve lash should be done at regular service intervals on ALL HONDA motors.
especially since there isnt a production motor (that i know of) that honda has made without the convenient lock nuts right on the top of the rocker arms.
The tech in me says regular service intervals here, the realist in me says whenever they get noisy.
I barely threaded it in, only until it catched because I threaded it finger tight on my first try and it just kept spinning since the hose has a swivel
I adjusted my valves, less tick but the real problem was timing.
My Sears Craftsman Timing light is about 6-10 degrees off.
SioneSi
Jun 18, 2003 11:36 AM
