DSM Turbo Parts On F22A1 Safe?
Old Jan 7, 2012 | 06:05 AM
92LXcb7's Avatar
Default DSM Turbo Parts On F22A1 Safe?
I'm wondering how long will my f22a1 last with a dam turbo manifold turbo Sam injectors and cheap pipping and inter cooler off eBay and my motor has 293xxx miles on it
Old Jan 7, 2012 | 08:39 AM
turboaccord77's Avatar
Default Re: DSM Turbo Parts On F22A1 Safe?
thats a lot of miles on engine.i would rebuild before boosting it.as for using dsm turbo,yes u can but you also need the dsm 440 injectors too.i used a 14b turbo with mine and was fine.i even used it on my g swap for awhile.hope this helped you.
Old Jan 7, 2012 | 10:45 AM
92LXcb7's Avatar
Ok I'm doing a f22b1 now lol would the dam parts work on it as well?
Old Jan 7, 2012 | 11:09 AM
GhostAccord's Avatar
Why are you going to switch to a B1?
I think you should slow down and figure out what it is you want to do. You just had some major issues doing at a simple A6 cam swap.
I say stick with the F22A it is probably the best F series platform to start with. Ditch the idea of building an F22B1.
if you want to go boost stick with that process and research as much as you can about forced induction.
As for the F22 engine holding up to boost. An F22 in good condition will hold a DSM turbo build. Tuning is key!
Do a compression test on your high mileage F22 and go from there.
Old Jan 7, 2012 | 11:47 AM
92LXcb7's Avatar
Well I was going to go buy a f22b1 for 99$ and build it up slowly and have it done when my f22a1 gose out and I wanna boost the f22b1 or what's better the a1 or b1 I want vtec to
Boost_Addict_88
Jun 24, 2011 08:38 PM
accordtunerx
Apr 4, 2004 09:35 AM
7808
Feb 13, 2004 04:33 AM
