del sol power loss when cold( dips around 3-4k rpm)
Old Jan 6, 2012 | 08:47 PM
raverx3m's Avatar
Default del sol power loss when cold( dips around 3-4k rpm)
im not sure what is happening i thought it was clutch slipping but it wouldnt be doing at same exact RPM every time.
heres what happends.
its a stock b16a3 motor with ITR intake manifold and 68mm throttle body idle is adjusted properly theres no bouncing idle issues.
when i start driving on cold engine i accelerate smoothly not smashing on it.
even accelerating normally i would feel a dip around 3000-4000 rpm every single time.
once the engine is warmed up a lil bit it goes away.
if i step harder it feels like the clutch is slipping thats what i thought first.
but it accelerates from idle to 3000 then dies out untill 4-4.5 rpm and gets power after that.
have no clue what it could be never had problem like that.
Old Jan 7, 2012 | 06:23 AM
Former User's Avatar
Default Re: del sol power loss when cold( dips around 3-4k rpm)
Measure the fuel pressure and test the FPR.
Also Ohm test the ECT sensor.
Old Jan 7, 2012 | 04:49 PM
raverx3m's Avatar
would absense of fast idle valve cause this problem?
the omni power TB has the fitv bypass.
also when i bought the car the thermostat was stuck open. now has a brand new honda oem thermostat. temps are normal.
AICV is also clean.
would a clogged fuel filter cause this?
i haven got a chance to check anything yet. will do in few days
Old Jan 23, 2012 | 05:42 PM
raverx3m's Avatar
why would it be doing it only when cold?
when warmed up the engine accelerates great with no problems.
Old Jan 23, 2012 | 05:49 PM
Do some tests and post the results.
MrDelSol253
Jan 31, 2017 05:30 PM
shady3260
Jul 23, 2010 10:50 PM
JdelMsolG
Jun 27, 2006 03:06 PM
Schmedley
Sep 13, 2002 11:07 AM
