What eles does an Integra LS Drag III kit need to be safe?
Old Oct 8, 2002 | 12:34 PM
TedR719's Avatar
Default What eles does an Integra LS Drag III kit need to be safe?
A guy I know is going to get a Drag III Kit for his 98 LS. What eles do you guys suggest to get him running safe?
I suggested:
-Boost Gauge
-Fuel Pump
-SAFC (to tune a/f)
-Vortech FMU 8:1 (or 12:1?)
-Maybe 320 injectors
-Turbo Timer
-Fuel Presssure Gauge
What eles would you suggest. He not planning to run more than 8psi or so.
[Modified by futuresi, 9:45 PM 10/8/2002]
Old Oct 8, 2002 | 12:42 PM
dustin's Avatar
Default Re: What eles does an Integra LS Drag III kit need to be safe? (futuresi)
12:1 FMU
INLINE HIGH PRESSURE fuel pump.
But it still wouldn't be all that safe. SAFE would require a real (read: expensive) fuel system... but this will work.
Old Oct 8, 2002 | 12:45 PM
TedR719's Avatar
Default Re: What eles does an Integra LS Drag III kit need to be safe? (dustin)
Where can I get a good inline fuel pump and the FMU.
I know this isn't the greatest setup but just to get him buy for now without having a real weak spot in his setup.
[Modified by futuresi, 9:46 PM 10/8/2002]
Old Oct 8, 2002 | 12:49 PM
dustin's Avatar
Both the FMU and fuel pump come with the drag kit.
Old Oct 8, 2002 | 12:59 PM
TedR719's Avatar
Cool, didn't know what kinda came with the kit though.
He just wants to have everything in and ready to go when we fire her up.
Old Oct 8, 2002 | 01:00 PM
dustin's Avatar
Get a good oil return system too. The drag setup is (to quote brian), "hobo"
Old Oct 8, 2002 | 04:03 PM
TedR719's Avatar
Suggestions on that? What kinda set-up vs. the drag?
Old Oct 8, 2002 | 06:39 PM
highmilehatch's Avatar
I would use a bulkhead fitting on the pan with stainless steel line.
Old Oct 8, 2002 | 06:43 PM
avividmemory's Avatar
Default Re: What eles does an Integra LS Drag III kit need to be safe? (highmilehatch)
personally id go with a do it yourself setup unless you can find someone with a used one with all the stuff you want...
i used a 12:1 fmu, and an inline fuel pump....i took the inline off cuz i was blowing excess gas at idle...still is rich all the way even without it!
bcause
May 24, 2002 02:03 PM
tygsr
Apr 20, 2002 01:14 PM
SIK IN DA HED
Jun 29, 2001 12:45 AM
