Should I run a larger capacity oil pan?
Old Jan 6, 2012 | 04:57 PM
monster_c's Avatar
Default Should I run a larger capacity oil pan?
Hi I'm building my 84mm lsvtec 12.1 compression and I was wondering if I should run a larger oil pan? What benefits will I get from a larger capacity oil pan? If none then I rather just use the stock one. Any info would help please I don't want to mess up an expensive build.
Old Jan 6, 2012 | 06:36 PM
EsotericImage's Avatar
Retired Moderator
Default Re: Should I run a larger capacity oil pan?
use the stock one and use your cash for proper crank venting
Old Jan 6, 2012 | 08:38 PM
monster_c's Avatar
Ok thanks, but how do u get proper crank venting? Oil catch can? This is my first build and I want to do it right. My block is still at the machine shop
Last edited by monster_c; Jan 6, 2012 at 08:56 PM. Reason: Forgot to put something
Old Jan 7, 2012 | 03:16 AM
Retired Moderator
http://www.theoldone.com/components/breather/
Mjalaly
Oct 31, 2017 05:04 AM
jdm_Jim
Feb 10, 2012 07:08 AM
WalkerGSR1
Jan 4, 2007 07:31 PM
macDelli
Nov 17, 2005 03:56 AM
fandango
Jan 20, 2005 06:20 PM
