Suspension & Brakes Theory, alignment, spring rates....
Skunk2 Rear Lower Control Arm Review
Old Jan 6, 2012 | 06:39 AM
OMG THE GOGGLES's Avatar
Default Skunk2 Rear Lower Control Arm Review
http://youtu.be/yI7WQivwtRQ
Old Jan 6, 2012 | 07:44 AM
brettnahmann's Avatar
Default Re: Skunk2 Rear Lower Control Arm Review
great video! wish he had put them on and actually experienced them, but still informative
Old Jan 6, 2012 | 10:42 AM
That will be next, so a video review of them after use will be made down the line
Old Jan 8, 2012 | 09:50 PM
haha didn't know you were the author of the video! cant wait to see the nxt..il subscribe
Old Jan 10, 2012 | 04:56 PM
Jr97teg's Avatar
very informal video! thanks for posting..
Old Jan 12, 2012 | 08:06 PM
No problemo. LCA's are one part for our hondas where there are a ton to choose from, but very few that are actually worth running on the car.
Old Jan 12, 2012 | 08:16 PM
1994turbocivic's Avatar
i just bought these for my dc teg, do you happen to know anything bout preloading them?
Old Jan 12, 2012 | 08:54 PM
phat00civic's Avatar
preloading a LCA???
Old Jan 12, 2012 | 09:05 PM
yea i heard that you have to drop the car on lca (on ground), and tighten the bolts... something like that lol.... or bushings will crack.. anyone hear of this
Old Jan 13, 2012 | 03:47 AM
Libertariat's Avatar
Ek Forever y0!
I sure hope they've fixed their bushing problem. For $190+ it's really pretty sorry for Skunk2 to have issues like that.
The company makes amazing headers and cams, why can't they figure out suspension stuff?
For ~$200 I would be pretty tempted to spend the extra $30 and get Function7 which have a far mores solid (albeit limited) track record among frequent posters in this forum.
I've got half-a-dozen pictures at home of completely ruined Skunk2 LCA bushings all only after a few months of use. And yes, they are the latest bushing as far as I know. The ones with the notches.
Old Jan 13, 2012 | 05:10 AM
grumblemarc's Avatar
The Grumpiest
The new and old bushings have notches in them. The new have five while the old ones have eight(?) I believe. I cannot recall what was improved about them but we'll see since I finally got mine on.
Old Jan 13, 2012 | 06:00 AM
From Skunk2: "Our new bushings will have 5 grooves in them, our old ones will have 8"
The ones in the video are with the new compound, and have the 5 notches.
Old Jan 13, 2012 | 07:33 AM
civexspeedy's Avatar
Originally Posted by phat00civic
preloading a LCA???
This is correct. When you install them, lightly tighten the bolts when the car is up in the air(suspension unloaded). When you are finished, drop the car and let it sit(suspension loaded). Then go under and torque each bolt to spec. If you tq the bolts while the car is in the air and then drop the car, the bushings may sit twisted and will prematurely wear out.
Old Jan 13, 2012 | 07:41 AM
The Grumpiest
What I did was while the car was up in the air I used a scissor jack to push the suspension up to where it would normally be sitting at and then torqued down the bolts.
Old Jan 13, 2012 | 07:42 AM
Yeah doing something like this works well. If you're lowered at all and try to tq the bolts when the car is resting, it's a bit hard to reach under the car and you may not have enough room to turn the tq wrench.
Old Jan 13, 2012 | 07:51 AM
+1 as that is how I did it. Much easier especially on a lowered car.
Old Jan 13, 2012 | 08:06 AM
good to hear i wasnt misinformed lol...
Old Jan 16, 2012 | 04:03 PM
Anyone else with S2's have any + or -'s ?
Old Jan 16, 2012 | 04:09 PM
The Grumpiest
Just got these on after them sitting in my garage for a few years. Will have to let you know. I will say even the old style bushings are better than that crap I just pulled off of my car. Firm ride. Remove one chrome Type R valve cover and the last of the rice will be history.
Old Jan 17, 2012 | 02:53 PM
LOL^
Basically any of the "oem style" bushings that are found on aftermarket LCA's are junk. The only ones that are oem style, but hardened and last for a long time are the Hard-Race ones and PIC's. Other than that its only F7/S2 really. I am curious of how the Buddyclub Bushings are holding up as they look nearly identicle to the S2 style.
Old Jan 22, 2012 | 09:14 AM
Anyone have pictures of how the first generation of bushings failed on them? I am curious how they wore since the center metal bushing can spin somewhat freely. Hmm
Old Jan 22, 2012 | 09:37 AM
GagnarTheUnruly's Avatar
They wear when they start binding. Then the binding causes the bushings to tear themselves up. You actually want them to move around. That's why it's important to keep them lubricated.
Edit: -- this is only true for poly bushings -- rubber bushings should fit very tightly and there should be no free movement in either the inner or outer collars.
Old Feb 17, 2012 | 03:50 PM
Andres01's Avatar
Icon3 Re: Skunk2 Rear Lower Control Arm Review
GOOD GOOD INFO!!
Old Apr 8, 2012 | 08:52 AM
The Grumpiest
Update!!!
Was going to install this shiny goodness today
when I went under the car and found this.
I did everything I was supposed to and this is what I get? Scared to drive my car now!!!
Old Apr 8, 2012 | 11:02 AM
The Grumpiest
Yup. Yup. Not enough lube? Sat in the garage too long and dry rotted (they were sitting about 2 years.)? Had to put the old POS ones back on that have no provision for a swaybar.
hondasingapore
Suspension & Brakes
10
Dec 15, 2013 01:09 PM
hondasingapore
Suspension & Brakes
Oct 15, 2009 01:14 PM
JHPUSA
17
Jun 30, 2009 08:49 AM
Aventuraa
13
Apr 20, 2009 11:14 AM
wikedgolf
Suspension & Brakes
Jul 24, 2007 06:11 PM
