Suspension & Brakes Theory, alignment, spring rates....
anyone that has tein monoflex please chime in
Old Jan 5, 2012 | 07:23 PM
swizz977's Avatar
Default anyone that has tein monoflex please chime in
im trying to decide between flex or monoflex... i see the spring rates for the mono flex for a 92-95 civic are 14/783 8/448.. it seems pretty intense but i just wana know if its too stiff like for a daily.. i need somthing stiff since im going to tuck my tires but is that like over kill where im going to die? but other than that if it rides not as crazy as it sounds because of some kind of different spring or shock it has that i didnt read about and its better over bumps let me know please thanks
Old Jan 5, 2012 | 07:44 PM
98civdx's Avatar
Master Detailer
Default Re: anyone that has tein monoflex please chime in
Your going to spend $1700+ to slam your car?
I have to ask, are you stupid?
Old Jan 6, 2012 | 11:42 AM
swizz977's Avatar
ok so i guess noone has these that can tell me if illl break my back daily driving them
Old Jan 6, 2012 | 12:19 PM
TunerN00b's Avatar
The rates alone should tell you everything you need to know concerning that.
If you don't know enough about what the normal range of spring rates for that car are, convert the spring rates into natural frequencies and use that instead. I'd recommend staying under 1.4Hz if you value ride quality, but I daily with the rear at 2.1Hz just fine.
Old Jan 6, 2012 | 12:23 PM
grumblemarc's Avatar
The Grumpiest
He doesn't understand rates. This is also his second post asking about these. Yet he cannot fix the other suspension deficiencies with his car.
https://honda-tech.com/forums/suspension-brakes-54/koni-gc-vs-tein-flex-3013351/
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/1992-civic-hatchback-rear-camber-arm-bolt-wont-tighten-2996852/
https://honda-tech.com/forums/suspension-brakes-54/why-does-my-skunk2-camber-kit-keep-loosening-while-driving-3001354/
Koni/GC 450f/450r
Old Jan 6, 2012 | 03:32 PM
swizz977's Avatar
Default how to help ur upper arm hitting shock tower
ok so would getting stiffer coilovers help reduce hitting my a arms hittin the schock tower
Old Jan 6, 2012 | 03:41 PM
TunerN00b's Avatar
Default Re: how to help ur upper arm hitting shock tower
Yes, if you meant "stiffer springs". Stiffer shocks won't do anything to help that issue.
As would removing the camber kit and putting the stock UCAs back on.
As would raising the car.
The last 2 options should be free, assuming you still have the stock parts.
Old Jan 6, 2012 | 05:29 PM
The Grumpiest
Why did you feel the need to start YET ANOTHER thread on the same issue? It is painfully clear you have no idea of the concept of spring rates. If you did you would not have had to ask this question.
Old Jan 6, 2012 | 05:43 PM
bnetkillzone's Avatar
You most likely have too soft of spring rates for the drop you are trying to achieve. Usually around 400 fronts for a flush tire to fender and 500+ for tucking tires.
Old Jan 7, 2012 | 05:26 AM
The Grumpiest
Originally Posted by solbrothers
no point in replying to him. just report his posts
They actually merged this one.
Old Jan 27, 2012 | 12:08 AM
B14er's Avatar
Monoflex is the way to go and not too stiff for daily.
Old Jan 27, 2012 | 01:12 AM
STOCK_SOHC_DX's Avatar
Your gonna over spend on suspension that has weird rates for the street and one year warranty with not too much support for the little guy? Goodluck with that. I had them, liked them but only bought them because I got them cheap. Ultimately sold them because I made $$ off them and didn't like the rates and tein didn't answer any of my questions to what rates I could run without blowing the shocks.
Skip01
Aug 22, 2009 10:06 AM
JDM Factor
Aug 6, 2006 04:12 PM
PublicEnemy
Suspension & Brakes
Jul 14, 2005 09:37 PM
reVVin
Mar 20, 2002 01:25 PM
