bought a 96 Accord
Hey guys just getting back to Honda scene. Anyway, I got a 96 ex accord and its really clean however there are some issues, maybe you guys can point me in the right direction. First, my heater won't work, it blows out cold air, I believe the AC works cause when I gutter the AC button it seems like colder air comes .. Also I believe I have a short, the fuse for the horn and brakes is the same, my brake lights were out and I noticed the fuse was out, I pressed the horn and it blew the new fuse. Abby suggestions at least with the heater...someone told me it might be the thermostat or some clutch behind the dash
That's funny man... I been out of the Honda loop for a few years n I just picked up a Green Metallic 96 Accord EX myself... Different problems with mine thou... My sh*t smells like sick gas in the cabin... Hope you find out what's wrong with your ride ASAP...
BUMP TTT for this dude!!!
Thanks guys, when i got the car the carpet wasnt wet so hard to tell... so after i got home i saw oil on the drive way from where my car was, prayed it wasnt me but when i moved it again saw more oil. I got my oil change friday so im hoping its just a loose oil filter or drain plug
So i called my friend at the lube n go and my friend says it looks like it comes from the front main seal. He said to try some adjetive that rwfreshes the gaskets. He knows they sell them for auto trannysfor the rear main seal
For the heat. Can you check a few things.
1) Coolant is full and no trapped air
2) When you move the **** from hot to cold is the cable at the heater control valve moving?
3) If moving, is the "heater core" side of the hose the same temp as the inlet to the valve...yes the inside/lever of the valve can break from the inside.....not alowing the coolant to flow.
Oil Leak: a little more info on "the front". Then it is trans fluid or is it engine oil? Can you narrow down "front" as well....drivers/pass/center.
Make sure the heater core is hooked up to. IDK about the climate in Texas, but if it's anything like AZ a lot of times when the heater core springs a leak people just loop the hoses and forget about it.
Your oil leak is probly the rear main seal if it's coming from the transmission. See how bad it leaks and then you might be better off just topping off the oil from time to time.
Coolent is good, and not to sound dumb but where is the heater control valve? Ill look add see if the heater core is hooked up, sorry my automotive knowledge is somewhat basic
Can you post a picture of the leak itself? It could be in any number of locations. I thought my tranny was leaking, but I took a closer look and the leak was from the vtec solenoid. The drops fell near the tranny and engine. If it's on the back side of the engine, it could be your oil filter switch. I think that's what it's called. The seal behind the threaded tip for the oil filter.
I'm dealing with this same oil leak on my 98 ex. I pulled the valve cover and distributor which were both fine and it was the vtec solenoid gasket (spool valve filter assy.) 3 small bolts which are a pain to get a wrench on to remove. I hacksawed off a 1/4 inch off a 10mm quarter inch drive socket, this gave me enough room to get on the bolts. Also with the dizzy removed it gives more access to work.
roger that, ill post some pics up. im going to go buy some of that treatment and some transmission oil upon my return ill let the car sit for a bit, than take some pics.. ill also look into that heater control valve. Thanks for all the help guys, I really do appreciate it
Make sure your heater control valve isn't stuck close; no coolant flow through the heater core. It's located behind the transmission side, so in front of the passenger side wall. There's a heater hose hooked up to the heater valve from the engine head.
OK So sorry about the no pics. went and purchased mtf and Lucas transmission treatment. took the passenger tire off and found the filler plug. When i opened it tons of fluid poored out. The leak is comin from the direct center of the car, in line with filler plug about 5 inch away directly towards the center. I never added the treatment but went for a drive and realized the shifts were more smooth, wierd. I also found out my radiator is cracked....if this is shitty, poorly written im sorry im on my phone and the keyboard sucks and plus my wife is yelling at me lol
3) If moving, is the "heater core" side of the hose the same temp as the inlet to the valve...yes the inside/lever of the valve can break from the inside.....not alowing the coolant to flow..
The oil leak is sounding more like the oil pres switch, as someone suggested, but the decription is not clear to me....but I'm only on my first cup of coffee.
Update:
So i replaced the radiator and thermostat, but still my heater is blowing. My friend who works on hondas was looking my car over and checked that cable you were talking about that switches the heat and noticed it wasnt moving, he tried moving it from under the hood but still no hot air, he believes its disconnected behond the dash
pellegrino
Nov 9, 2008 07:38 PM
