Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Hey, I need some info for an 06 civ ex
Old Jan 5, 2012 | 05:22 PM
x_dude21's Avatar
Default Hey, I need some info for an 06 civ ex
if anyone knows, I'm just looking for the service limit thickness for the rear brakes. and at how many miles the spark plugs should be changed...
thanks!
Old Jan 6, 2012 | 06:53 AM
bee guz's Avatar
Default Re: Hey, I need some info for an 06 civ ex
Brake pads should cost you about 30 bucks, just put new on and be done with it, if you let them go thinking you have time you might wind up running them too low ruining the rotors.
Plugs are recommended to last 100K but if you do change them you might see a little more MPG and power, they are another item that you change because they are so cheap.
Old Jan 6, 2012 | 10:29 AM
Blk06Si's Avatar
Rear rotors service limit is 8.0mm. Spark plug replacement is due at 105k.
Old Jan 10, 2012 | 07:14 PM
crvtec8's Avatar
the plugs are 100k but there far from cheap dealer only parts stores can get ones but not ngk
Old Jan 10, 2012 | 08:31 PM
av911's Avatar
Punctuation, man!
You're only changing it every 100K miles. Not cheap, but cheaper than the dealerships.
http://www.oreillyauto.com/site/c/de...3435&ppt=C0334
B2FiNiTY
Jan 15, 2004 09:45 PM
sil
Mar 31, 2003 05:35 PM
ELUD THS
Sep 5, 2002 10:01 PM
BeeResp0nsible
Aug 20, 2002 01:03 PM
TeamTooQuick
Jun 19, 2002 10:12 PM
