LS swap mount question
Old Jan 5, 2012 | 04:38 PM
MMMGIRL's Avatar
Default LS swap mount question
Im putting a ls in my ek, I dont have any mounts. I know there not the best choice but im on a budget and will upgrade them later, will these be a straight drop in? http://www.ebay.com/itm/96-00-CIVIC-...ht_3739wt_1010
Old Jan 5, 2012 | 06:28 PM
mmcd's Avatar
Default Re: LS swap mount question
yes they will work. But you'll need a t bracket also from a 99-00 si. but you may be able to find something on here for you budget.
Old Jan 5, 2012 | 06:32 PM
EsotericImage's Avatar
Retired Moderator
hard race makes decent mounts as OE replacement that work great
http://www.velocityshop.com/product/...civic_326.html
Old Jan 6, 2012 | 05:09 AM
kyden's Avatar
you don't have any mounts at all in the car? the rubber parts are the same between d and b series.
Old Jan 6, 2012 | 05:13 AM
Retired Moderator
Yea, but why use mounts that are 12-20 years old? these cars arent fresh from the factory. replace it the right way 1st and you wont have to do it later on.
Old Jan 6, 2012 | 05:28 AM
jbpnoman's Avatar
He says he's on a budget and will replace them later. Why replace them twice? Just run the stock mounts until you have the money to get proper mounts.
Old Jan 6, 2012 | 07:35 AM
apexi_rsx's Avatar
he wont need to replace those mounts they will work fine.. only thing about them is the paint is cheap and chips over time of torque and twist.
Old Jan 6, 2012 | 09:24 AM
cvcrcr99's Avatar
I wouldn't run anything but OEM or Hasport mounts. I have seen cheap eBay mounts snapped in half due to stress over time. I have had numerous issues with Innovatives. I love my Hasports however.
Old Jan 6, 2012 | 09:34 AM
nealnanoHX's Avatar
You can reuse all rubber mounts assuming they are still good for the D16 that was in the EK. Also you need the rear trans T mount bracket and a 99-00 Si drivers side mount bracket, it is by the timing belt behind all the covers. I did this swap in my 98 HX and made it fully OBD2 at first. OM me if you have any question as there is a bit more to it that just a drop in, while it is a very easy swap. Some wiring changes ect.
Old Jan 6, 2012 | 10:01 AM
apexi_rsx's Avatar
i know on the ef's they made cheap mounts that did not have gussets and the trans mount hangs low and tends to snap. if u know someone that can weld u can make them work. but these ek mounts d and b series mounts wont snap.
another_aca
Apr 16, 2012 03:42 PM
JDM_NANO
29
Oct 3, 2011 04:15 PM
paul8ex
Mar 14, 2009 07:45 PM
nxvictim
May 24, 2007 01:50 PM
rodvang
Dec 2, 2004 11:37 AM
