Oil Leaking From Valve Cover in a strange spot
So I'm guessing this would be easily fixed by replacing these grommets, but what would cause enough pressure to actually force oil out this way?? I've probably owned around a dozen hondas and have never seen anything quite like this.
Any ideas?
Any ideas?
^ if it were cheaper I'd buy one too for myself...I have the valve cover breather connected to a hose down to the ground and gutted my stock PCV valve and put a hose on that to the ground...no issues for the 12k miles at 235whp
Black box just catches the vapors and drains it back to your oil, I gutted my PCV valve and kept the black box. Some people weld AN fittings on the valve cover and run those to a catch can for further ventilation.
Going to be running one of these
http://www.brfittings.com/index.php?...&product_id=82
and one of these
http://www.brfittings.com/index.php?...&product_id=62
to eliminate the whole PCV/blackbox system.
and one of these
I should have a spare oil cap laying around. I might drill it out and cut up an old, eBay intake filter to see what I can do. Probably won't look as nice, but I'll give it a shot I guess!
It could be a lot of things. As everyone said Start with replacing the PCV Valve if you’re still having the pressure I would suspect rings at well the pressure could be from blow by from worn rings as well. I like running catch cans all on my motors boosted or NA it just keeps all that nasty oil and crankcase gases from being introduced back into the motor.
