Suspension & Brakes Theory, alignment, spring rates....
what wheel bearing's do u use?
Old Jan 5, 2012 | 05:42 AM
94boostedhatch's Avatar
Icon2 what wheel bearing's do u use?
im in the middle of doing a rear disc conversion on my 94 eg hatch and want to replace wheel bearings before i put it together anything special u guys using for high speed apps im hoping to run 9's and want to do it as safe and reliable as possible?
Old Jan 5, 2012 | 05:56 AM
Libertariat's Avatar
Ek Forever y0!
Default Re: what wheel bearing's do u use?
I doubt you could go wrong with OEM wheel bearings. Honda makes some durable stuff.
Old Jan 5, 2012 | 06:16 AM
zerovandez's Avatar
Kind of on the same note; if you are doing a rear swap conversion and the donor parts use ABS but your car doesn't, and you don't plan on using/adding ABS, should one replace with wheel bearing with ABS or non ABS?
Old Jan 5, 2012 | 06:23 AM
donut.'s Avatar
abec9
jason_SIR
Mar 25, 2014 01:49 PM
EgonzEk
Feb 23, 2011 10:59 PM
youdontknowmeeither
Dec 20, 2006 08:50 PM
alexdog69
Oct 18, 2004 02:43 AM
