Questions about Techedge DIY wideband kit.
Old Oct 8, 2002 | 11:30 AM
blufke's Avatar
Default Questions about Techedge DIY wideband kit.
who bought the DIY kit? i think im gonna put it together myself. how accurate are they? worth the cash? how hard was it to put together? think im going this route so i can tune the smc properly.
also, how long of a cable did you guys use? the 2.6m or the 4m one?
Old Oct 8, 2002 | 11:50 AM
ThePunk's Avatar
Default Re: Questions about Techedge DIY wideband kit. (blufke)
https://honda-tech.com/zerothread?id=300362
Old Oct 8, 2002 | 12:06 PM
blufke's Avatar
Default Re: Questions about Techedge DIY wideband kit. (ThePunk)
alright then..thanks. now im just curious about the length of cable i should get...2.6m or 4m. and reviews on the techedge kit?
Old Oct 8, 2002 | 12:29 PM
ThePunk's Avatar
Cable lenght depends on where you intend to put your 02 sensor, and where your putting the controller box. As for reviews, the unit works very well. Matches the results of the dynoss true wideband VERY well.
Assembly is not simple, but certainly do-able.
Old Oct 8, 2002 | 12:43 PM
dustin's Avatar
Get the shorter cable. 4m is long!!
I got the shorter one and I still had to coil 75% of it up under the dash.
Old Oct 8, 2002 | 12:50 PM
SoulSurfer's Avatar
Default Re: Questions about Techedge DIY wideband kit. (dustin)
Unless you have a Cadillac. 8 1/2 feet is plenty to work with. To test: Make an 8 1/2 ft cord (rope, whatever) and try and run it where you'd run the cable.
Old Oct 8, 2002 | 01:32 PM
blufke's Avatar
why do you say assembly is not simple? seems pretty straightforward to me.
Old Oct 8, 2002 | 02:20 PM
ThePunk's Avatar
Why do you say assembly is not simple? seems pretty straightforward to me.
It's pretty straightforward, But it isn't simple. You have to trim a few components to get them to fit properly, calculate the proper resistor value to get the heater current exactly right, and do some very basic testing of the unit as you go along...
Simple is a battery, 2 wires, and a lightbulb....
AznPrideYo
May 17, 2008 01:08 PM
AznPrideYo
Apr 9, 2008 07:46 AM
rusteds2k
Nov 28, 2005 05:06 PM
EM2MoNsTeR
Dec 13, 2004 10:10 AM
iHave2Cams
Mar 22, 2004 06:43 PM
