1989 wagon cooling system woes
Old Jan 4, 2012 | 10:57 AM
BigBurch422's Avatar
Default 1989 wagon cooling system woes
Cliffs:
- car began to overheat while driving
- checked, was low/empty on coolant, so i filled it up
- after adding coolant, the temp. needle only slightly moves up towards H, even after running for a long time
- replaced thermostat, replaced coolant
- now the temp. needle barely moves off of where it sits when the car is off, even after running for an hour
- drives/runs fine
- engine gets warm to the touch
- heat gets hot
- but shows running cold
Should I be worried? I want to say the temp. gauge just isn't working properly, but I honestly don't even know what to check and I'm afraid if the gauge isn't working properly I won't know if it starts to overheat again.
If the engine actually is NOT warming up properly, wouldn't the heat not be hot?
I've been told to replace the thermostat sending unit, or something like that, but I'm not even sure where that is...this is just my beater car. Any help is greatly appreciated!
Old Jan 4, 2012 | 11:05 AM
jlicrx's Avatar
Default Re: 1989 wagon cooling system woes
temp gauge sending unit is on the end of the head below the distributor
Old Jan 4, 2012 | 11:34 AM
awesome, do i need to take the dizzy off to get to it or no?
Old Jan 4, 2012 | 12:00 PM
jlicrx's Avatar
no
crazyhouse2011
Nov 22, 2014 03:14 AM
Tombomb661
Honda Civic (2001 - 2005)
May 5, 2011 05:51 AM
bandit080000
Dec 7, 2008 08:25 PM
Da1spaz247
Oct 12, 2005 02:33 PM
superstud
Oct 14, 2004 12:44 PM
