boosted integra idle but boggs out
Old Jan 4, 2012 | 08:59 AM
b18boosta1's Avatar
Icon2 boosted integra idle but boggs out
hi guys im new to the honda and acura motors i have a boosted b18a1 that i just put new piston rings in i got it put back together got it timed perfectly and it will start and idle but once i give it the gas it chokes out on me it was obdo converted to obd1 the guy i put the car from did all the work to it so know i cant git the thing to run right any suggestion on what might be wrong would be greatly appreciated thanx
Old Jan 4, 2012 | 09:47 AM
mouab18c1's Avatar
Default Re: boosted integra idle but boggs out
Is it tuned?
Old Jan 4, 2012 | 11:00 AM
DirtyDA9's Avatar
^^ is it? It could be many things, first thing I would do is check for a boost leak, clean the IACV/FITV, check valve timing, ignition timing again.
And also I would do a valve lash adjustment, change the belts, vc gasket, fuel filter, run some seafoam/injector cleaner through it. Just normal stuff to keep the motor healthy, since you aren't the one that did the work, you don't know how well maintained it was/wasn't.
Old Jan 4, 2012 | 11:25 AM
b18boosta1's Avatar
it run awsome it just smokedso i pulled the head and droped the pan changed the rings and timed it like 5 freakin times now when i start it up it idleing rough should i take the computer to someone and have them look at it the guyi bought the car from said its tuned
Old Jan 4, 2012 | 02:15 PM
mouab18c1's Avatar
If it was starting up fine before hand then I would double check your work.
Old Jan 4, 2012 | 03:27 PM
b18boosta1's Avatar
so i think ive narrowed it down to something on the throttle body it starts fine idles good but once i give it the gas its shutting down so im going to change the sensors on top and see if that helps any chance any one know what there all called i only know of the idle positioning sensor there 2 more i dont know the name of oh it doesnt bog down tell i hit 3 grand on the rpms
Old Jan 4, 2012 | 04:42 PM
mouab18c1's Avatar
What's with the run on sentences man? I get a headache reading and trying to figure out what you are saying. Is there a CEL? There is no reason to change a sensor out without it being faulty.
Did you switch the map and tps connectors around?
Old Jan 4, 2012 | 05:29 PM
Gsrsi's Avatar
If your absolutely positive about your work then start it up and let it idle. New internals have to be broken in.
Old Jan 4, 2012 | 07:13 PM
b18boosta1's Avatar
oh sorry about the run on sentences. So its not the sensor. i dont know whats wrong with it. like i said its idling perfect but every time i give it just a little gas it bogs out.im just so stumped. never had the problem with my eclipse and it was turboed. maybe i just need to pull it to a shop
Old Jan 4, 2012 | 07:20 PM
Dc4LsTeG's Avatar
EK9
Kind of sounds like your timing might be off
Old Jan 4, 2012 | 07:35 PM
DirtyDA9's Avatar
Clean your IACV.
Old Jan 4, 2012 | 08:09 PM
b18boosta1's Avatar
just cleand it same thing perfect idel but dies when i give it gas
Old Jan 4, 2012 | 08:10 PM
el crapitan's Avatar
sounds like the tps and map connectors are backwards. as stated, try switching them around
edit: on second thought, it would be pretty difficult to get them mixed up, as non obd has the map on the firewall
Old Jan 4, 2012 | 08:13 PM
check the tps (throttle position sensor) with a voltmeter
also, same question; any codes?
Old Jan 4, 2012 | 08:23 PM
stocker2shocker91's Avatar
I requested a short story for a title.
sounds lie a posibly tps problem to me, did you disassemble the intake mani when u re did the motor?
Old Jan 4, 2012 | 08:29 PM
b18boosta1's Avatar
im going to check the fuel filter
Old Jan 4, 2012 | 08:43 PM
b18boosta1's Avatar
no didn't dissemble it. left the throttle body on the head when i swapped the rings.i wonder if its the computer. the guy i bought it from said he converted it from obd0 to obd1. but i dont understand it ran fine before i changed the rings. and im positive i did everything right.
Old Jan 4, 2012 | 08:53 PM
don't see how you can check a fuel filter.
check for codes
Old Jan 5, 2012 | 06:23 AM
b18boosta1's Avatar
you were right shes running like a champ nowthanx for all the help guys
Old Jan 5, 2012 | 06:38 AM
so it was the connectors?
Old Jan 5, 2012 | 07:58 AM
b18boosta1's Avatar
yeah it was the connectors. now i got a new problem.the car has a rev limiter at 4 grand when its not in gear.but now when its in gear it wont go over 4 grand i think i need to get the computer checked.
Old Jan 5, 2012 | 09:43 AM
it's probably in limp mode. do you have a cel?
Old Jan 5, 2012 | 09:47 AM
DirtyDA9's Avatar
You cant "check" a fuel filter lol. You just replace it brow. Like stated, test your TPS.
Old Jan 5, 2012 | 05:20 PM
b18boosta1's Avatar
i got no check engine light.so i dnt think its in limp mod. does kno how to check throttle positioning sensor. im new to hondas
Old Jan 5, 2012 | 05:36 PM
Wrona's Avatar
it is in limp mode
this is why you dont buy other peoples projects
was the car actually tuned of basemapped
what injectors
turbo?
what ECU is it using i am assuming a OBD1 P28
u need to know these things
