H22 Balance shaft belts
Has anyone had any problems removing just the belt over an extended period of time?
I read a lot of threads on it but nobody really seems to have any feedback without a belt over 30k miles and over.
Obviously the proper way would be to remove the shafts but that's not an option right now because the motor is still in.
No problems after approx 20-25K miles on my H22. Not quite as high as you are asking, but I have never driven the car a ton since I swapped to the H22, as I bought my Subaru to commute with.
Thanks, this is the best response so far. Most people ask about removing just the belt but not many answers without removing the shafts as well.
Most people post that they feel it revs faster and that the belts been off for a week.
I just want to see if there have been any failures or problems from running no balancer belt while leaving the shafts in.
Did you have to do anything with the shafts?
I'm asking if anyone has ran into any reliability issues of any sorts running no balancer belt.
I did do the whole shaft delete on my other motor, but this one has never been open yet.
I kind of went the other way on my old engine. I ran without a belt for maybe 10k miles. Then I put it back on without another issue for another ~50k. No issues. As long as the seals are already in good condition I don't think it should be an issue to just stop using the BS belt.
-P
-P
I also have my balance shafts removed on my built motor but this one is internally stock and the tensioner failed on me and balancer belt got chewed up so I'm considering just leaving it off instead of spending about $40 for a new one.
I have been running without one for a couple of years now, car is driven daily, no problems, all seals were replaced with t-belt at time of swap 2+ years ago.
^Yeah just backing what Pirate said about as long as the only thing you should worry about with the balancers is the seals, they'll still wear even without the shafts spinning. I haven't had the belt since the swap since at first I wasn't getting good oil pressure and after checking a few things and fixing it at some point the rear balancer spun a bearing causing it to lock up so I can't run the belt.
I ran my car with no bs belt for about 15000km with no issues. I also have the belt laying around somewhere in my crawl space if you want it. If i can find it that is haha...
