Need an engine on 1979 Honda Prelude
Old Jan 3, 2012 | 11:11 AM
PhilE2212's Avatar
Default Need an engine on 1979 Honda Prelude
I have an original 1979 Prelude given to me by my uncle and after 95k miles the 1st cylinder piston rings broke according to the mechanic.
Does anyone know what kind of engine I could put in without doing too much work like replacing the motor mounts etc. etc. ????
Does anyone know of a company that has engines in stock for older vintage hondas?
Old Jan 4, 2012 | 05:36 AM
Shaguar47's Avatar
Default Re: Need an engine on 1979 Honda Prelude
Unfortunately due to there being no support from any companies on these cars, little options exist for dropping another engine in. A CVCC engine from a 1st gen civic can be dropped in with some minor modification while the Honda City ER can be worked to fit also.
Your engine is an EK1 1.8l and is common in the 1st gen accords and preludes. There is a few sets of pistons either STD or .25 oversize on ebay for sale (a whole set) for about $50-60, and I think they include rings. These engines are extremely simple to work on so it'd be as easy as working on a d-series engine.
Just my 2 cents, replace the headgasket while your at it if you choose to replace the piston. Cylinder 1 could of had a blown headgasket which lead to a major cylinder leak.
Old Jan 4, 2012 | 09:52 AM
PhilE2212's Avatar
I appreciate the time you put in to respond.
If I was to buy a set of pistons I would need to get the block sleeved for the over bore of the pistons correct?
Old Jan 4, 2012 | 09:55 AM
PhilE2212's Avatar
Also, I would need to replace all 4 pistons at the over bore .25 size right?
Old Jan 4, 2012 | 04:47 PM
lazlong's Avatar
They have about 20 engines listed here: http://www.car-part.com/ Costs about $100 to ship. Maybe with 2 engines you'll have enough parts to make 1 run.
Not all the parts are dis-continued. OEM rings for $30 here: http://www.hondapartscheap.com/index...NNECTING%20ROD (that's one set, one set= one piston)
Old Jan 5, 2012 | 10:20 AM
PhilE2212's Avatar
Wow. I appreciate the really good info.
I still wondering if the block needs to be re-sleeved on .25 overbore.
Old Jan 5, 2012 | 11:34 AM
Rad Racing's Avatar
Bart Taylor Look-alike
I doubt you would need to re-sleeve it with .25 over pistons. The block should be designed for the flexibility to bore/hone to .25.
Old Jan 5, 2012 | 11:46 AM
PhilE2212's Avatar
Sweet. Here is dumb question number 1000.
I would need to do all pistons at .25 overbore right?
Old Jan 5, 2012 | 11:49 AM
Rad Racing's Avatar
Yes. Have you pulled the motor yet?
Old Jan 6, 2012 | 11:56 AM
PhilE2212's Avatar
No i have not pulled the motor yet. It's just sitting in a parking lot right now. I'm going to limp it home soon.
vtekn
Nov 12, 2017 08:25 PM
Jimmythebum
Jan 5, 2005 03:38 AM
hachirokulude
Jul 20, 2004 06:34 AM
sn955l
May 3, 2002 09:37 PM
