Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
2004 Odyssey won't shift out of park
Old Jan 3, 2012 | 10:15 AM
kwise's Avatar
Default 2004 Odyssey won't shift out of park
I have being driven insane by intermittent gear shifter nightmare on my 2004 Odyssey EXL with 125K . Few months ago, I start experiencing an occasional shifting out of park issue with ‘P’ light on the dash is not lit . After the Mechanic changed the solenoid and the brake light switch , the issue got worse as the gear got stuck on the park 9 out 10 with ‘p’ indicator light not lit. I noticed sometimes the ‘P’ flickers when I shift back from either ‘N’ or ‘D’ and it would either stays on or simply off .
So, do I need to recheck the work done by the tech and make sure both solenoid and brake light switch are setup properly or should I look at a loose wires or transmission range switch .
Also, does anyone has the wiring diagram that shows how to troubleshoot the wiring connections.
Thanks for your help!
Old Jan 10, 2012 | 06:34 PM
Ross 2.0's Avatar
In a Junkyard near you.
Default Re: 2004 Odyssey won't shift out of park
Sounds like the range switch is acting up. May need to adjust it. Check to see if the brake lights are working when it won't shift.
Old Jan 16, 2012 | 05:18 PM
kwise's Avatar
Ross, thanks for your assistance. Brake lights are working just fine. Would you happen to have a procedure on adjusting the range switch and the wiring diagram connections? Any pics will be super nice . my generic email kwiseme@hotmail.com if you wish to email me a pdf doc on the procedure.
Thanks a mill
Old Jan 17, 2012 | 01:41 PM
kwise's Avatar
I saw this info on odyclub.com but still it doesn't show the procedure
Rickety4u
Gear Range Switch
I was just wondering if a bad range switch will keep gear indicator on dash from working?
08-16-2010, 09:57 AMNew Dad New Van
A/T gear position indicator does not indicate shift lever positions
Transmission range switch defective or out of adjustment
Shift cable broken or out of adjustment
Joint in shift cable and transmission or body worn
Check the D indicator, and check for loose connectors. Inspect the transmission range switch. If the transmission range switch is
faulty, replace it. If the transmission range switch is out of adjustment, adjust it and the shift cable.
Check for a loose shift cable at the shift lever
and the transmission control shaft.
Old Jan 19, 2012 | 09:32 AM
kwise's Avatar
Ross or anyone else - I don't have access to 2004 odyssey manual so if you would please assist me on the procedure.
Thanks,
Old Jan 22, 2012 | 07:49 AM
kwise's Avatar
I feel like I'm talking to myself on this forum. Anyone has access to 99–03 Odyssey ETM ?
Old Jan 22, 2012 | 08:18 PM
Myroslav69's Avatar
When you hit the break to shift out of Park, do you hear the solenoid clicking? If not, then you have to hunt for a signal wire between the break pedal and the computer that controls the shifter solenoid. If you do hear clicking then most likely you just need to adjust the shift cable/lever.
Old Jan 26, 2012 | 10:20 AM
kwise's Avatar
I will double check again. would you happen to have the wiring diagram (page 138)
shift lever stuck
in Park and the P in the shift indicator not lit?
Refer to page 138 of the ’99–03 Odyssey ETM.
Old Jan 29, 2012 | 09:19 AM
hikegnp's Avatar
I have a manual for a 2002 Odyssey that has instructions for trans shift range switch replacement along with the electrical schematic. I can copy and send if this will help for for your year Odyssey.
Old Jan 29, 2012 | 11:01 AM
kwise's Avatar
Great.. please email me a copy to kwiseme@hotmail.com
Thanks a mill
Old Jan 29, 2012 | 02:04 PM
kwise's Avatar
Hello Myroslav69 - I hear the clicking but not sure how to the adjustment on the shift cable/lever. Would you happen to have instructions?
Old Jan 30, 2012 | 10:36 AM
kwise's Avatar
Hello Hikegnp : Can you shoot me a copy of the instructions on both trans shift range switch and on Solenoid (shift cable/lever) (Myroslav69 notes).
Thanks!
Old Feb 5, 2012 | 12:17 PM
boosted1993's Avatar
On the drivers side of the transmission there is a switch behind a cover that can be indexed back and forth to get different adjustments.
Old Feb 14, 2012 | 06:13 AM
high_revs's Avatar
its most likely a bad brake switch...if you still havent fixed this issue, check to see if you have brake lights....im 95% sure this is the issue..
high_revs's Avatar
deff wont be a range switch..
Old Feb 16, 2012 | 03:14 PM
Yeah range switch is cheap and easy to throw in just to see if the condition improves.
Old Feb 20, 2012 | 05:31 AM
kwise's Avatar
high_revs ... on my initial thread, I did mention replacing the brake switch and yes the brake lights comes on.
boosted1993 - Honda Dealership wants $185 for Trans range switch.. I think you meant brake switch ...right
Anyone has a soft copy/eletcronic version of Odyssey ETM . If so email me a copy to kwiseme@hotmail.com
shift lever stuck
Thanks a mill
'00acura
Acura TL, RL & ZDX
Oct 17, 2011 07:38 PM
sageuvagony
Mar 25, 2010 05:05 PM
994drLS
Apr 21, 2007 10:29 AM
drunkinmiami
Nov 19, 2005 12:52 PM
