93 honda accord manual tran axle keeps popping out
I have a manual 93 honda accord axle keeps popping out of the passenger side. I have replaced the Axle, but it still pop out. I am planning to swap the tranny if there isn't any other reason why it would pop out. ANy helps?
If you have removed the old axle and the C clip stayed in the groove in the drive gear and you installed a new axle with the new C clip, then it will pop out. If you install any axle with no clip it will pop out. You must have a floating clip, not bent or badly out of round that will lock in the drive axle groove. It must take a screwdriver or small pry bar to "pop' the axle out or the axle will pop out while driving. Can a drive gear move enough for the C clip not to line up.......not sure on that one.
I would do what bandit said.....Take a few hours take ur time check the c-clips make sure urs has one on the axle if you have ur old one check and maksure the c-clips still on It if not thats whats wrong you have to clips If thats the case the old axle would have been a bitch to get out and the new axle would have been hell geting It Into the spindle...U can also spreed ur c-clip a tad......Why did you change ur old axle?Did It also pop out?If so then I would check into the tranny....Is ur car lowered?
killacam661
Transmission & Drivetrain
Jan 4, 2009 03:17 PM
jdm_vtec
10
May 1, 2007 06:58 AM
