tire pressure mysteriously went up?
Old Jan 3, 2012 | 08:22 AM
91akira's Avatar
Default tire pressure mysteriously went up?
My car is in hybernation for this winter. Last time the pressure for all tires were at 32 PSI. Today I was just curious to check the PSI. The drivers side was up at 37? and the passenger went down at 27?!
I know nothing about tires and all. Whats going on?
Old Jan 3, 2012 | 02:49 PM
doc@tirerack's Avatar
Default Re: tire pressure mysteriously went up?
27 PSI I would believe after a month or so of storage, but the 37 PSI reading has to be wrong. Either the gauge had a hiccup or something else happened with the initial reading.
See our Tech articles here and here for more info
Old Jan 3, 2012 | 08:04 PM
Rockets's Avatar
At what kind of temps was your car stored in? Sometimes I pump air in my tires during the winter time when springs arrive it will jump a couple of psi.
Old Jan 4, 2012 | 07:50 AM
91akira's Avatar
With the 37 PSI tire, I used the gauge mulitple times and still got that reading.
Rockets- its winter so, pretty cold. I'd say in the garage is about low 50s at night. Then it gets warm in the day about 72 in the garage. Typical san diego weather in the winter.
Guys do you think it has to do with the "contract and expand" with fluctuating heat and cold?
Old Jan 4, 2012 | 10:39 AM
Normally we'd expect a 2 PSI swing for each 10 degree change in ambient temperature, so unless it was really cold for the initial PSI check or really hot for the 37 PSI reading I'm not sure that is enough to explain the difference....
Old Jan 7, 2012 | 09:39 PM
1998GsRIntegra's Avatar
Does the drivers side get constant sun from a window or something during the day? If thats the case and you checked it at the end of a warm day then maybe, but its quite a stretch.
EF9ZC
Honda Motorcycles
Jul 23, 2006 09:45 AM
dgrave
Dec 19, 2004 09:26 PM
CereaLand
Sep 4, 2003 05:37 PM
CereaLand
Sep 4, 2003 02:22 PM
mr_mbuna
Nov 24, 2002 06:52 AM
