N/A Ls B18b build options? cams? spring's and valves? pistons? anything else?
I'm looking into a ls swap ( B18B ) into my 95 eg hatch.
I'm looking into what all i need for the swap?
And building options for the motor?
Cams? Valves? Springs? Retainers? Pistons? Intake Mani? Throttle Body?
Fuel Injectors? Fuel Rail? For a N/A Build.
Please & Thanks.
Please & Thanks.
The only reason why i wouldn't want to turbo it, is because i would want my motor too be reliable and last a long time. Too me it seems like a turbo, decreases the life span of a motor? So a N/A build would be reliable and get up and go.
The only reason that a turbo would NOT be reliable is if you did do the turbo build right. Period. Your information is faulty.
I'm only in high school, so more in likely i'll be looking at ebay turbo kit's.
& yes i know there a 50/50 for there kits, but is there a way i could improve the reliabilty of the turbo, so i know it wouldn't just blow in a couple hundred miles? And what would be some good build options for my motor if i was going to turbo it.
composurey
16
Jan 4, 2012 09:41 AM
JDubya
Jan 17, 2003 01:55 AM
