Tube forming tools. HELP needed!
Old Jan 3, 2012 | 05:01 AM
RO_SUNNY's Avatar
Default Tube forming tools. HELP needed!
How do you guy press the tubes / elbows to make them oval at the end to match the oval cutout in the head flange.
Thanks.
B
Old Jan 3, 2012 | 05:02 AM
weiRtech's Avatar
OG Fabricator
Default Re: Tube forming tools. HELP needed!
i use an arbor press.
Old Jan 3, 2012 | 05:14 AM
that-guy's Avatar
heat with an acetylene torch, arbor press to desired shape, let cool naturally, clean throughly before welding
Old Jan 3, 2012 | 10:36 PM
RO_SUNNY's Avatar
What arbor presses do you guys use....1 ton, 2 tons...etc?
Thanks for the input!
Old Jan 4, 2012 | 06:23 AM
that-guy's Avatar
1 ton should do fine for most tubing thicknesses, but alot depends on how much you heat the tubing. if the price is right, just step up to a 2 ton to be sure
92cxturbo
Welding / Fabrication
Apr 18, 2011 07:03 AM
gtconcepts
12
Dec 30, 2009 09:39 PM
Vagmaster
15
Apr 20, 2009 08:26 AM
evild16
Mar 12, 2008 04:42 PM
Tinker219
Mar 17, 2005 08:31 AM
