questions about 88-89 and 90-91 guage cluster
Old Oct 8, 2002 | 10:05 AM
88hondahatch's Avatar
Default questions about 88-89 and 90-91 guage cluster
ok i have a beat 89 si cluster w/ a broken tach, gas, and temp guages
i also have a perfect 91 si cluster
and my stock 88 DX cluster
i know i can put my speedo in the 89 si cluster, and prolly the 91 si tach, but i was just wondering if i could use the gas and temp guages from the 91 cluster to the 89?
its kinda hard too read i know but i was just courious if it could be done b4 i tried it cause i dont wanna break the 91 si cluster if i can sell it still
Old Oct 8, 2002 | 10:07 AM
Mugen Dom's Avatar
Default Re: questions about 88-89 and 90-91 guage cluster (88hondahatch)
the tachs are different teh way the screws go in are diff if u have ever take in apart teh screws are also part of teh circutry and so the other tach wont work try and find a 88-89 cluster teh 90-91 wont work ive tried teh 88 and 89 tachs are even different i tried putting a 88 tach in a 89 cluster and it was different
Old Oct 9, 2002 | 12:21 AM
zexdrex's Avatar
why dont you just swap clusters
Old Oct 9, 2002 | 01:10 AM
88CiViC_DX's Avatar
Default Re: questions about 88-89 and 90-91 guage cluster (zexdrex)
cause putting a 90-91 cluster in a 88-89 requires rewiring
Old Oct 24, 2002 | 05:10 PM
Dj Lotte's Avatar
I'll buy the 1991 Si cluster!!! I'm about to pick up a CRX Si and this and a shift **** are what I need. E-mail if you are interested in selling...
Mike
Old Oct 24, 2002 | 06:33 PM
Proper's Avatar
Default Re: questions about 88-89 and 90-91 guage cluster (88CiViC_DX)
The wiring is not complicated at all try this site http://www.geocities.com/twisted91ci...ap_diagram.htm I think there are only like two wires you have to switch. they are already there just need to be moved to the other plug. Probably would be easier than changing the guages from cluster to cluster
[Modified by SOHC'd up, 7:34 PM 10/24/2002]
Old Oct 24, 2002 | 09:06 PM
vhd's Avatar
vhd
you should be able to swap your old speedometer into the 91 si cluster if you decide to use it. you just use your old speedometer/odometer mechanism with the 91 si speedometer face. remove the needle carefully along with the two tiny screws in the middle of the face. wiring the 91 si cluster into your 89 si will be easy. you will also need the cluster cover off of a 90-91 si, let me know if you need one
Old Oct 24, 2002 | 09:10 PM
EF_LSVtec's Avatar
Default Re: questions about 88-89 and 90-91 guage cluster (SOHC'd up)
Old Oct 25, 2002 | 04:46 AM
keithv's Avatar
Default Re: questions about 88-89 and 90-91 guage cluster (EF_LSVtec)
what about putting an 88-89 cluster in a 90-91 crx?
Old Oct 25, 2002 | 06:31 AM
Proper's Avatar
Default Re: questions about 88-89 and 90-91 guage cluster (breaka_1_9)
You would do just the opposite of what the site listed above says. i would guess anyway
Old Oct 25, 2002 | 06:39 AM
keithv's Avatar
well the 90-91 has a 3rd connector that has 3 or 4 pins that goes in the middle of the cluster. does this go anywhere on the 88-89 cluster?
wongburger
Dec 13, 2009 08:39 PM
kizner
Dec 30, 2005 05:44 PM
Silroan
Jul 7, 2003 08:13 PM
paulzy
Apr 3, 2003 12:50 PM
AfEn808
Jan 12, 2002 08:34 PM
