NO COMPRESSION IN CYLINDER FOUR HELP!!!!!!
Old Jan 1, 2012 | 07:26 PM
Nicestacks's Avatar
Default NO COMPRESSION IN CYLINDER FOUR HELP!!!!!!
Hello my honda teach ppl I have a 1991 integra gs b18a1 and its misfiring than a bitch. Me and a friend did a compression it didn't read anything and when we took the spark plug out it was looking like it was just sparking but not getting any fuel can some one give an idea what can the problem be???
Old Jan 1, 2012 | 07:37 PM
DirtyDA9's Avatar
Default Re: NO COMPRESSION IN CYLINDER FOUR HELP!!!!!!
Valve not sealing.
Old Jan 1, 2012 | 07:46 PM
racebum's Avatar
read this thread
https://honda-tech.com/forums/acura-integra-6/compression-test-help-3010425/
Old Jan 1, 2012 | 10:12 PM
vshavoc's Avatar
Did you do the compression check with the car up to temp, disconnected fuel pump fuse, and holding the throttle wide open? If it has no compression still, then put a little bit of oil in that cylinder and do the compression check again. If it goes up a decent amount you probably have bad rings. If it doesn't go up it's most likely a burnt valve/bad valve seat. You can also do a leak down test and if you take the oil cap off and hear the air coming through it probably has bad rings. If you hear it coming out of the intake side it's a bad intake valve. If you take off the radiator cap and see bubbling or hear it coming out of that it's a blown head gasket (which I doubt is the problem), and if you hear it out the exhaust side it's a burnt exhaust valve.
Old Jan 2, 2012 | 11:01 AM
Nicestacks's Avatar
Thank guy ill try it to see wat happen
Old Jan 2, 2012 | 11:51 AM
Nicestacks's Avatar
O yeah and an nuther thing the car dieds some time when I'm driving when it warn up but it starts right away u guy thing that can because. Of a bent valve???
Old Jan 2, 2012 | 11:59 AM
Nicestacks's Avatar
Originally Posted by racebum
Nvm I just read the other thread I'm give it try some time. This week just gotta get that leak down test thank guys
nemesis25
Jan 12, 2015 04:17 PM
ef9itb
Feb 6, 2011 06:21 AM
sirt_eg
Jun 16, 2009 01:25 PM
soon2bdropped
Mar 2, 2009 03:31 PM
cxVtecC1
Feb 18, 2005 06:54 AM
